Windows installer not working
I have tried to install many applications but i m failing with errors
windows defender cannot install updates , i cannot install softwares or download any of them what to do??????
please help me out of this
I m having a windows vista enterprice system with McAfee virus scan enterprice. My PC has two OS one is windows XP SP2 and other is vista
Please Help ME???
  • Justin Mathew May 11, 2010
    can you exactly say what the error message reads
Vista home premium windows installer not working
Posted on Jan 23, 2009
  • ziggig3 Jan 23, 2009
    right click command prompt and chose "run as administrator" . Type
    "regsvr32 c:\windows\system32\msi" press end and try to install again.
  • pascal2156 Sep 25, 2011
    please re-start your computer and then try
    Problem Solver:
  • 12 Answers
Try using the following kb article to solve your problem
http://support.microsoft.com/kb/555175
Thank you
Regards
Nikhil Mahajan
Posted on Jan 22, 2009
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
How do i fix error ox800106ba
Hi Anon,
The 0x800106ba error may occur after Windows Defender is updated due to the computer's inability to update the Windows Defender firewall. It may not have applicable permissions needed for the update, or it may not have the files necessary for updating itself.
The Fix
Set Windows Defender to Automatic - You can set the Windows Defender service to Automatic, Disabled or Manual. Setting it to automatic might solve the problem. Follow these steps:
  1. Click Start > type services in the Search box > click Services in the Programs list.
  2. If you are asked for a Password before you continue, then enter the password > click Continue.
  3. Double-click Windows Defender, and click Automatic in the start-up box > click OK.
Uninstall and reinstall Windows Defender - If the first procedure did not help resolve the problem, try un-installing and then reinstalling Windows Defender. Due to the fact that Windows Defender is a Windows component, we will use AppWiz to un-install it from the computer. Follow these steps:
  1. Press Windows Key + R > type appwiz.cpl > Press Enter
  2. Click Windows Defender > click Remove
  3. Follow the prompts to uninstall Windows Defender
Let me know how you go!
Feb 12, 2015 | Microsoft Windows Defender
How to fix windows defender for free
The Windows Defender software constantly scans your computer for threats such as spyware that may slow down your computer or try to steal personal information. If the software wasn't installed properly or is conflicting with other programs running on your machine, Windows Defender may not work correctly. To repair the software you either need to download the latest update available for the program, or you need to completely uninstall and reinstall Windows Defender.
Restart your computer's operating system. Double-click the "Windows Defender" icon in the system tray at the lower-right end of the screen. Click the question mark icon at the top of the Windows Defender screen and choose "Check for Updates." Select "Continue" if you are running Windows Vista. Wait for the updates to finish installing and click "Scan." Click "Stop Scan" if the problem persists. Click the question mark icon again and select "Exit Windows Defender." Click "Yes" to confirm you want to close the software. Open the "Start" menu screen and select "Control Panel." Select "Uninstall a Program" in Windows 7 or Windows Vista, or instead choose "Add or Remove Programs" in Windows XP. Click the "Windows Defender" entry and select "Uninstall." Choose "Yes" and restart the computer after the program is removed. Navigate to the Windows Defender installation webpage (see Below). http://www.microsoft.com/downloads/details.aspx?FamilyId=435BFCE7-DA2B-4A6A-AFA4-F7F14E605A0D&displaylang=en&mg_id=10134 Click "Download" and double-click the Windows Defender installation file when it downloads to your hard drive. Go through the onscreen installation instructions. Open the "Start" menu and choose "All Programs." Select "Windows Defender." Click "Scan" to start a new scan for malicious software. Hope this helps
b>
Dec 27, 2012 | E-Machines eMachines Desktop PC
Windows defender not working
You might find some interesting security tips here.
http://support.microsoft.com/ph/11952
Hope this helps
Nov 28, 2012 | Computers & Internet
The application failed to initialize properly (0xc0000135).
When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this error you can run Windows Update and find the Microsoft .Net framework update to install. Alternatively, you can download the Microsoft .Net Framework directly from Microsoft.
Aug 18, 2010 | Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
I cannot receive microsoft updates, they fail. Error 1606
The error code 646 will appear when any of the Microsoft office application updates fail to install. Run fixit provided in the below link and then try to install updates.
http://support.microsoft.com/kb/971058
Jan 12, 2010 | Microsoft Windows Vista Home Basic Edition
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
Error messages
Uninstall the Windows defender and install am updated version. If it doesn't work, try this:
To resolve this problem, follow these steps:
1. Uninstall Windows Defender, and then reinstall Windows Defender. To do this, follow these steps:
1. Click Start, click Run, type appwiz.cpl, and then click OK.
2. Click Windows Defender, and then click Remove.
3. Follow the prompts to uninstall Windows Defender.
4. To reinstall Windows Defender, visit the following Microsoft Web site:
http://www.microsoft.com/athome/secu...yware/software (http://www.microsoft.com/athome/secu...yware/software)
2. If this issue is not resolved after you complete step 1, uninstall Windows Defender, use the Windows Installer CleanUp utility, and then reinstall Windows Defender. To do this, follow these steps:
4. To use the Windows Installer CleanUp utility, click the following article number to view the article in the Microsoft Knowledge Base:
290301 (http://support.microsoft.com/kb/290301/ ) Description of the Windows Installer CleanUp utility
5. To reinstall Windows Defender, visit the following Microsoft Web site:
3. If this issue is not resolved after you complete step 2, follow this step:
1. Click Start, click Run, type regsvr32 file name, and then click OK.
Note In this step, file name is a placeholder for the following files.
Repeat this procedure for the following files:
* wuapi.dll
* wuaueng.dll
* wucltui.dll
* wups.dll
* wuweb.dll
* atl.dll
* softpub.dll
* wintrust.dll
* initpki.dll
* mssip32.dll"
cheers ...
Apr 10, 2009 | HP Pavilion 520c PC Desktop
Problem Installing Printer Driver for Canon MP460
1) relax
2) prove to install nod32 from this site www.nod32.com is a powerful antivirus work very well.
after you have make, please reinstall the driver from this site.
3) http://software.canon-europe.com/products/0010394.asp
Thanks
Sergio
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
