Question about GE JE1860 Microwave Oven
How do I replace the magnetron in my GE JE1860?
Everything works but the heat.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • 415 Answers
Considering the cost to have the microwave repaired: both labor and parts, it is more economical to purchase a new one unless it is still under warranty.
Posted on Feb 13, 2009
  • Mark Gough Feb 13, 2009
    Unless you have replaced a magnetron before DO NOT ATTEMPT TO DO SO UNLESS YOU HAVE EXPERIENCE !!!!
    I am stating that above because of the voltage. And touching the magnetron can cause the voltage to be passed to your body, won't kill you but you most likely will be hurt.
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Everything works except that I can heat anything.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 12, 2011 | GE JE1860 Microwave Oven
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
Jan 18, 2011 | GE JE1860 Microwave Oven
Everything works (clock,lights,turntable) but it does not heat. Is it better to fix or replace?
If everything works and it does not heat, the problem lies with the magnetron circuit. Typically the magnetron fails and the replacement part is almost as much as a new oven. For this model the price of the magnetron is about $80. Unless you really love this oven, your better off replacing it.
Jan 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave - no heats - vibrating sound
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
(it may pass the checks and still be bad)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Oct 10, 2009 | GE JE1860 Microwave Oven
Microwave not working after it ran without food in it.
try unplugging the microwave for a while then plug it back in.
Aug 29, 2009 | GE JE1860 Microwave Oven
Microwave not heating
OK, if everything, including the fan, is working, this will confirm Magnetron failuer. you cannot reset the function of a failed Magnetron heating unit. replace this failed device asap if possible.
Jun 05, 2009 | GE Microwave Ovens
GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Dec 16, 2008 | GE JE1860 Microwave Oven
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
GE # JE 1860WH AH900849 not heating
hi Kathrine,
It sounds like the magnetron may be bad, if this is the case it may still be under warranty. Check to see if it's in warranty if it is contact GE or the store you bought it from. If it is I would not recommend you repair yourself (very dangerous voltage, and a very expensive part)
Mar 21, 2008 | GE JE1860 Microwave Oven
GE JE1860 Microwave Oven Logo
250 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
