Question about Whirlpool LER5636P Electric Dryer
Need belt diagram for Whirlpool Dryer LER5636P
I need a belt diagram for Whirlpool Dryer LER5636P
    Sergeant:
  • 311 Answers
Its on the bag of a new belt.but its eazy to put on .put the belt with ribbs down on the drumthis is with the drum on the rollers in the dryer .now have the idler pulley in place and put the belt in between the idler pully roller and the pully bracket,then pull back on the pully and place belt on motor pully.check alinment before starting or will throw belt off again.God bless,tom
Posted on Jan 01, 2009
  • 15,935 Answers
Http://www.appliance-parts-warehouse.com/whirlpool-parts/model_view_cats.cfm?id=21289
Could not get the LER5636 to open, but this shuld be similar.
Dryer is doing everything but drum spinning... counter thinks its going... have not let it go long enough to see what heating is doing but drum is not moving.....?
sounds like the belt:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 10, 2011 | Whirlpool LER5636P Electric Dryer
Idler pulley is loose
See this link:
http://repair2000.com/wpoolbelt.htm
This should show you how to route the belt for your Whirlpool dryer.
Also - here is a short pic:
May 21, 2010 | Whirlpool LER5636P Electric Dryer
I need wiring diagram for whrilpool ler5636kq1. timer
Good luck finding one. I look at the wires. They are marked with the same letters as that of each dryer terminal. I have a plain jane dryer manual from whirlpool but I doubt it will help much.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Where can I find a diagram of the belt and pully system for whirlpool electric dryer ler5636eq3
Check here and see if they have what you need.
Clothes Dryer manuals. Clothes Dryer user manuals. Clothes Dryer owners manuals. Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
You can check here also: partsselect.com
I hope this helps you.
Oct 03, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool #ler5636ez2 need diagram for belt instalatiion
Unplug the dryer...
  • Remove the lint trap and the 2 screws holding the vent to the top panel (be careful not to drop them down the vent!).
  • Reach around the back and pull the top panel toward you. Insert a putty knife from the front on each side to release the top panel clips. Lift and flip the top panel back.
  • From the inside, remove the 2 screws holding the front panel to the cabinet. Lift the front panel straight up off the front panel clips (hooks) and swing it aside.
  • You should now have access to the belt.This diagram shows you how to loop the belt through the idler pulley.
To replace the belt...
  • Place the belt (grooves inward) around the drum.The idler pulley fits into the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
To reassemble, follow steps in reverse.
Let me know if you need more assistance.
Mar 29, 2009 | Whirlpool LER5636P Electric Dryer
Need wiring diagram for model numbersoe4606ayw magtag dryer made by whirlpool
I have a link to the wiring diagram: Please let me know if you need anything else and kindly rate this Solution.
http://www.applianceaid.com/image/de312diagram.JPG
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
537 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
