Question about Brother MFC-8220 Fax
I HAVE A BROTHER MFC-8220 FAX MACHINE AND I GOT A PAPER JAM. IVE BEEN TRYING TO TAKE OUT THE DRUM UNIT TO REMOVE THE PAPER BUT I DONT KNOW HOW. THE TONER/DRUM UNIT DOES NOT BUDGE. PLEASE HELP!
  • wtart May 11, 2010
    When you open the front cover to access the drum unit, does your cover open and close as normal, without obstruction or snags?
    Are you able to access the jammed paper from the rear access cover at the fuser unit?
    Champion:
  • 320 Answers
The drum comes out when you open the front door. it is where the toner goese.
Posted on Jan 20, 2009
I have a brother fax machine mfc8220, its displaying in red with error message remove original and the press stop. no paper jam or any paper inside.
Dear Miro
Pl. check the ADF section any of the sensor may clogged.
At least two sensors are there.
thanks.
Feb 26, 2015 | Brother MFC-8220 Fax
Drum jam toner
you are using the wrong toner in the drum unit
Nov 02, 2013 | Brother MFC-8220 Fax
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Oct 28, 2009 | Brother MFC-8220 Fax
Cannot remove Drum on MFC-8220
When you open the frunt cover ther is a black hinge / leaver attached to the cover on the left hand side that disengages the drum unit drive, if this is disconnected / broken you will not be able remove the drum unit, an engineer may be required
May 16, 2009 | Brother MFC-8220 Fax
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
Brother printer problem- "noise" on printed paper
when you open the front door to replace your toner. The part that you put your toner in is the drum unit. pull that out. Remove the toner cart. blow the unit out.
( DO THIS OUT SIDE, TONER WILL BLOW OUT OF THE DRUM UNIT )
On the top of the drum unit there is a blue or green slide lever move the lever back & fourth 15-20 times.
re blow out the machine with drum unit out.
Reinstall the drum,
make 5 copies ( 1st feow will be bad hope thay will get better )
If not need to determan if the drum is bad or the fuser asm is cuasing the problum.
( part that melts the toner on to the paper )
Need to do a 1/2 print test.
1. make a copie or do a report
2. when the paper is 1/2 way thrugh the machine but not in to the fuser open front cover.
( may need to tray a coupel of times to do ot right )
3 look at the paper see if marks are on the paper.
( If not then the fuser is bad. if the marks are there the drum is bad )
Hope this help's
Feb 11, 2009 | Brother MFC-8220 Fax
Brother mfc8220 jam problem
We looked everywhere for a piece of paper stuck in the machine and couldn't find it. We finally fixed the problem by moving the paper size adjuster in the paper try until it was right up against the paper. If the paper is free to move around in the tray, apparently the machine sees that as a paper jam.
Feb 03, 2009 | Brother MFC-8220 Fax
The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Dec 22, 2008 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
533 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
