When i instal the HD EXpress into my Mac Pro Intel, follow all directions to the letter and then send HDMI output to my LaCie 324 monitor, all I see during playback through Digital Performer is a square red screen and a lot of flickering. the Lacie tests perfectly in another system. Something wrong with the install? I also have the latest drivers and firmware from MOTU.
SOURCE: Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice
versa), therefore it often cannot be used as if it were a true Windows
disc. The restoration disc includes the OS, but it also includes every
driver and other software product that came with your system. If
Windows were the only item loaded on your system, then a Windows disc
could serve as a restoration disc, but these days, using a typical
restoration disc is an all-or-nothing process.
A restoration
disc is your ultimate troubleshooting tool. Suppose that your copy of
Windows becomes damaged from a virus or key applications become
corrupted. Symptoms such as instability, crashing, indecipherable error
messages, and impaired performance are extremely hard to diagnose by
yourself—even if you have the help of a customer support technician on
the telephone. If the most common corrective steps fail, you can always
use the restoration disc to recover your PC back to its known-good,
factory-fresh state.
SOURCE: IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
SOURCE: Intel 82845G Graphics doesn't support 1680x1050
You also have to install the monitor drivers.
And yes, the drivers directly from Intel will not work. Dell has a perpritory video, and you have to use the Dell Intel drivers.
I've installed a few of these, and I know they will work.
But I had to go with a 1280x1040 setting. It does work, and will fill the entire screen.
Another option is to put in a PCI video card (yes, a full size card will fit in the GX260's) One bonus to that is you can do multiple monitors. I've had best luck in the GX260's using video cards with an ATI chipset.
SOURCE: I need to download the
Please click on the below link or copy the URL and paste it in your web browser. And follow the steps. To download the drivers click on the Download which is present in the right side of the document.
http://www.lacie.com/support/faq/faq.htm?faqid=10550
OR
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Lacie-USB-2-Driver.shtml
OR
http://list.driverguide.com/list/company1220/
Thank you.......
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
thanks all. But two issues here that you may not have taken into consideration. I am working with a third party hardware and software. The MOTU HS Express and its PCIe card for HDMI. All is setup on my Intel MAC Pro, 8-core with 32 GB of memory and a GeForce 8800 graphics card. The problem is in the actual PCIe card. MOTU is send me a new one now. Thanks-J.
