Question about Archos Gmini XS 100 MP3 Player
DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
While copying files from my device to a laptop which has a damaged battery(uses direct elaectricity from wall outlet), one file failed to copy then i opened the device icon in my computer only to find it empty.Whenever i now connect it to pc it is not detected but shows usb cable attached.it also prompts me to format it by showing the message: cannot read from hard disk.when i try to format it whilst not connected to pc it doesnt finalize, it shows the sam message of read access error.what do i do.pliz help
  • 705 Answers
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
Posted on Jul 26, 2007
I/o device errors
The disk-drive is "dying" -- copy all the files that you can, either onto your 'C:' drive, or burn them to DVD-recordable disks.
Read the model-number and serial-number from the label on the disk-drive.
Access the manufacturer's web-site: http://www.maxtor.com
and "check warranty status" to see if Maxtor will replace the disk-drive,
at minimal cost to you.
Nov 06, 2010 | Maxtor Hard Drive
Cannot install Windows XP Pro using the setup disk. I can delete the old partition and reformat the hard disk using NTFS, but when setup starts copying files it fails to copy a file (never the same file)...
It's possible that your disk-drive is "failing", and it's about to "die".
Buy a new disk-drive, connect it, and try to install to it.
Other possibilities:
* bad RAM in your computer is messing-up the file-copy operations, and the CD-reading operations
* dying motherboard is malfunctioning,
* scratched Windows CD-ROM media
* malfunctioning CD-reader device.
Oct 22, 2010 | Western Digital (WD1500ADFD) 150 GB Hard...
File is corrupt. the file header checksum does not match the computed checksum
The file is damaged and cannot be accessed. If the file is on the hard disk, then a fresh/new copy needs to be copied onto the hard disk.
Aug 19, 2010 | Compaq Presario CQ60-212US Notebook
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
First freeze, then boot slow, then boot "PBR 2 ...done, then disk read error Ctrl Alt Del to contine..., now no screen at boot up....fried???
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 11, 2010 | Dell Inspiron 6000 Notebook
Cannot Read disk. Operating system not found Error
best way to solve it and recover your data is to take it to the vendor else you can use dos to copy it to your pen drive...lets understand 1st why a vendor can only work with it because its a laptop and the hard disk can not be accessed externally like with a desktop...so dont play with your critical data hope this will help u a lot...
cheers...pls rate...
Jan 04, 2010 | Lenovo 3000 Y410 Laptop
I dropped my external hard drive - a Verbetim terrabyte hard drive. Now, when I turn it on, it makes mechanical noises and won't connect to my computer (USB). I'm not too concerned about trying to fix the...
If your drive is making whining and clicking sounds, then you have a mechanically damaged drive which had what we called a 'head crash' due to the drop!
If you can read/access the disk partitions/drives, I strongly suggest that you perform a full disk backup (with track error skipping) to another device. Also try a file by file copy to another drive (slow but you know exactly what is accessible).
You may want to try to use 'Spinrite' (Google and read about it first) to attempt to repair some of the issues but unfortunately, a disk 'head crash' is usually fatal physical condition and data recovery requires specialized equipment and is VERY expensive!
Hope it helps: let me know ho you go!
Dec 29, 2009 | Verbatim External, USB 2.0, 750GB...
My IBM Thinkpad R40 laptop stopped working.The IBM Think Pad screen comes up and then with a beep,the system shuts down.Went to a support shop and found some IC on the system board was damaged.Now,for data...
Unless the hard disk itself is damaged, data should be perfectly recoverable. This does not mean that any USB device will be able to read the unit. Some external attachments I found were not capable of reading large disks, or required those disks to be formatted while in the attachment, meaning that the disk addressing mode wasn't autodetected at all.
On the other hand, the disk MIGHT be damaged. Sorry to mention it but it's a possibility. Were those damaged IC on the board connected to the disk I/O system? (Or, maybe, the ICs only seemed to be damaged, but were actually working - it was the HD which was damaged all the time, and the system rebooted as soon as it tried to access the disk).
I'd suggest having the disk connected with a 2.5"-to-3.5" adapter to a Linux machine as secondary hard disk. This will allow direct talk to the disk unit, bypassing external devices and the like, and allowing direct access to the partition, with a much more informative error logging than Windows systems are generally equipped with.
Nov 03, 2009 | IBM ThinkPad R40 2897 Notebook
Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Dec 17, 2008 | Archos Gmini XS202 MP3 Player
Toshiba laptop Tecra 8000
What the computer is trying to tell you is that the hard drive has gone faulty somehow... hard Drives can and do spontaneously fail all the time.. It probably shut down because it detected a serious fault with the hard drive. I think that at least you are going to have to try a new hard drive to see...
Sep 04, 2007 | Panasonic ToughBook 52 Notebook
Archos Gmini XS 100 MP3 Player Logo
276 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Mike M
Mike M
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
