SATO CL408e Thermal Printer Logo
Posted on Oct 17, 2012
I have installed a printer SATO LM 408. When I turn on the status monitor indicates
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
143
Points
Contact Sato UK direct on 01255 240000
5 Related Answers
A
Anonymous
  • Posted on Sep 08, 2008
SOURCE: Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Dave Busselle
  • 54 Answers
  • Posted on Feb 25, 2009
SOURCE: Spare Parts Catalog for SATO CL 408...
it is available on the Sato web site, by printer model
lancer284
  • 35 Answers
  • Posted on Feb 16, 2010
SOURCE: SATO and ZEBRA PRinter Hardware Support
Contact Lancer Labels on 0845 833 0854, they can arrange a service call anywhere in the UK.
Thermalman
  • 44 Answers
  • Posted on Aug 23, 2011
SOURCE: I bought a new SATO
Make sure that both are using the same comms settings i.e. baud rate word length etc.
printertech1
Billy Haywood
  • 96 Answers
  • Posted on Sep 23, 2011
SOURCE: i need to set tear
Set dip switch 3-1 off and 3-2 on. Recycle power.(Operating mode tear off)
I bought a new Sato CG480TT and installed the driver. The printer worked at the beginning with Label Gallery. Then all of a sudden, it didn't react to any print order I gave. On the SATO Status monitor it...
Is the printer showing solid green? any blinking red or green?
It could also you need to reinstall the printer driver. If all fail, then it could be the printer itself is faulty.
I need to set tear off option in my sato cl 408 barcode printer please help me
2answers
Getting an sensor error on Sato Barcode label printer CL412
Possible solution recalibrate media sensor and make sure your using the right media type on your label.
Won't recognize ink cartridge
Try this. Insert only 5 only ink tank, without LM. See status monitor. All 5 ink status look gray? and LM look cross. Try to another ink tank left. Last, insert all ink tank. All ink tank not recognized (cross sign)? If yes, the problem probably is epprom.
Will not print white on black
hi you need to change the font colour of your priter == for this you can go to the properties of the printer and change the colour = this may help you = Good Luck
Top SATO Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
