What is the load capacity for the GE WPSE4200AOWW Washer
  • 15,935 Answers
GE WBXR1060TAWW, Top loading high capacity washer. I need the specs, capacity and number of speeds?
The (X) in the model number stands for extra large (2.7cu ft) capacity. The 1 stands for single speed. The 6 stands for 6 cycles. It should have a white plastic clothes basket. More expensive models had a stainless basket. Hope this helps you.
Apr 15, 2015 | GE Washing Machines
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
Oct 25, 2014 | GE Profile WPRE6100G Top Load Washer
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
How do I open the washer up to check and see why it is leaking water WPSE4200AOWW
You can remove the front panel by pushing in the two retaining clips in the seam where the panel meets the washers top using a putty knife, while you pull the top of the front panel forward.
Jun 20, 2010 | GE Profile Prodigy WPSE4200A
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
What is the load capacity for the GE WPSE4200AOWW Washing Machine?
not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
Jan 01, 2009 | GE WHRE5260E Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
178 people viewed this question
Top Washing Machines Experts
