Question about Lexmark JetPrinter X1185 All-In-One InkJet
My printer wony printer after replacing both ink cartridges
Please tell me how to fix this problem?
  • marshasims Jan 01, 2009
    do you offer live tech support?
    Problem Solver:
  • 16 Answers
I had this problem;
Printhead replacement instructions are in the users guide.
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
Posted on Jan 01, 2009
My printer has full ink but it is showing low
You either used not original manufacturer cartridges or you attempt to refill them with ink, the cartridges have a small chip telling the printer how many pages were printed and how much ink was used.
You will need either a device to reset the chips or replace them with original manufacturer ones.
Nov 16, 2014 | Epson Stylus Office Equipment & Supplies
My Hp printer does not want to accept refilled ink cartridges
HP printers might work and might not work with refilled cartrdiges. You can use it but will create a problem in future and quality of printing will not be good. If still you wish to use refilled cartridge then please tell the name of the printer. If your printer hardware gets damaged because of using refilled cartridges then even if your printer is in warranty hp will not replace it.
Feb 25, 2011 | HP Office Equipment & Supplies
We had just changed both ink cartridges but the printer still thinks that the ink is low. Is there a way to reset it?
Hi dav0369
Once you have replaced the old ink cartridges with the new you can run the printer maintenance program this will reset ink warning levels or mayb opening the lid again where the ink is replaced and closing it can sometimes tell the printer you have replaced the ink cartridges hope this info helps cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 15, 2011 | Dell Office Equipment & Supplies
Polling the ink cartridges for available ink level.
then click on replacing ink supply, and the first box down tells you about ink cartridge levels.
There you go Utah
Please leave rating...thank you kindly
May 10, 2009 | Epson Stylus Photo R220 InkJet Printer
I cannot get my printer to recognize my refilled ink cartridges
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
Hp officejet 4315 all-in-one
Please clean the copper contacts of the cartridges with dry cloth and then check the expiry date and ink level present in the cartridges.
If the cartridges are expired or out of ink, replace the cartridges and check for the result.
If the cartridges are not expired and not out of ink then insert the cartridges and check for the results, if the issue persists recycle the printer and then reset the printer.
Jul 03, 2008 | HP Officejet 4315 All-in-One Printer
My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
Please follow the steps below to replace one or more cartridges.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
-To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Make sure the printer is powered on, and not printing.
2. Open the printer cover.
3. Do one of the following:
3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
8. If you need to replace another ink cartridge, repeat steps 5-7 above.
9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Will not allign....
Hi Kevsahag,
Please check with the ink cartridge number, make sure that you are using the correct ink cartridges.
click on the web link given below and perform the steps carefully to fix the issue.
Have a great day!
Mar 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer not printing!
i replaced the ink and it tells me that the thing is still up/open when it is not. Carol Nash
Dec 14, 2007 | HP PSC 750 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
