Question about Microsoft Windows XP Home Edition
How can I stop my display screen from fluttering?
When I turn my computer on, the display screenflutters for four minutes before the home page shows.
  • Deborah Taylor Jan 05, 2009
    I attempted to follow solution #1. The display screen fluttered for twenty minutes after I pressed F8.
  • 1,913 Answers
When u power up the computer press F8 key then enter in enable vga mode.
then chage screen resolution in display properties. to 1024*768
Posted on Jan 01, 2009
  • kishor khatri
    kishor khatri Jan 06, 2009
    it is your monitor problem.reset all settings of disaly to defaults factory settings.
Why does the fuel pressure tester gauge needle flutter?
yes.. that's normal pressure regulation for the system..
Aug 10, 2017 | Saturn Cars & Trucks
I have 4 little screens on home page
For Four little screen on home page
1.The Display setting by right clicking on the desktop,now go to the display properties and access all the settings very well
2. check maybe the VGA is installed properly on your system by going to your computer properties to the Hardware,from hardware to device manager you will now check mayebe the VGA is installed if it dies install it would have star it with yelow colour on that particular device
Jul 31, 2014 | HP Compaq Presario V6000T Notebook
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Dell Inspriron 1545- black screen no home screen
can you get in windows safe mode by pressing F8, and get screen? it might be a display driver
Jun 10, 2012 | Dell Inspiron 1525 Laptop
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
During the wash cycle the machine comes to a stop and beeps. display shows "F2" ??? I then have to pause it then turn the machine back on for it to continue.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 20, 2009 | Washing Machines
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jul 05, 2009 | Samsung Audio Players & Recorders
Home page does not fill the screen
use the monitor hardware controls on the actual monitor, and if that doesnt work, you have to change the display settings. which you would get to by right clicking your desktop interface, going to properties and display.
Jan 16, 2009 | Acer X193W LCD Monitor
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Microsoft Windows XP Home Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
