Question about Kitchen Ranges
Hotpoint Ceramic burner not working properly
Back left burner shuts off a few seconds after switching on. I produces heat for the 2-3 seconds before going cold.
    Sergeant:
  • 311 Answers
Hey there burner has a limiter built into it.its faulty,and you have to replace the whole burner.God bless,tom
Posted on Jan 01, 2009
My White-Rodgers Model #1F78 5/2 Day Prgm thermostat turns on and ighnites for a few seconds then turns off even after reprogramming or resetting. What should I do next to get the heater to start working?...
If the furnace or boiler burners actually light for just a few seconds and then go out, the problem is probably NOT the thermostat. Most likely the thermostat is calling for heat so the burners light, but there is a safety device called a flame sensor that will shut off the burners if it does not sense the flame properly. It is very common for the flame sensor to get soot, dirt, or oxidation on it and then it can not sense the flame and the furnace does exactly what yours is doing. Most of the time the flame sensor can be cleaned and it will work again. Sometimes a new one will take longer to go bad again. Typically they are a straight or "L" shaped piece of wire about the size of coat hanger wire that just sticks into the flame. The coat hanger type wire usually goes into a white ceramic base which in turn has a wire connected to the back end. Steel wool works good to clean the flame sensor, but if you use coarse wool or coarse sand paper the surface of the flame sensor gets rough and gets dirty faster. It is made of some kind of "polished" stainless steel.
Dec 10, 2013 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
America standard freedom 90 furnace. when the thermostat call for heat the ignitor glows then burner lights but only stays on for 1-2 seconds if i shut off the furnace power for a few minutes then turn...
Check the flame sensor and/or the grounding from the burner ot the ignition control....it is not sensing the flame...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 25, 2011 | Heating & Cooling
The Goodman Heater was installed in 2004. Thermostat set at 75F, the fan that blows CO2 out was on for about 1 minute, then I could hear the sound of the gas blowing into the furnace, but the ignitor...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 30, 2010 | Goodman GMS80903BNA Heater
Hotpoint nvl333gyoww gas dryer heats for a few minutes, then no heat. Seals appear fine, door latch appears fine, not sure what it could be - suggestions? Thanks.
here are a few reasons that you will get heat for a few min and then no heat.
1. if the vent is cloged, anywhere in the flexable hose to the wall or from the wall to outside. If the vent is cloged the flame in the unit will widen and the thermostat hi limit will shut she burner off untill it cools.
2. The coils for the burner could be bad and will allow the burner to light a couple of cycles and then will get hot and internaly disconect the coil untill it cools down and then will repeat and will get worse over time.
The good news :) The ignitor is good if it lights a flame, If the flame burns for more that 10 sec then the flame switch is mostlikley good. The main valve in most cases will also be good.
Im using Model # NVL333GY0WW
Jan 13, 2010 | Hotpoint NVL333GY Gas Dryer
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
