Question about Refrigerators
My fridge has stopped working. the light comes on, but has stopped chilling. the freezer section is working perfectly. can you give me some assistance?
  • islandpearl6 Jan 01, 2009
    MY LG fridge is making an helipcoter noise and is hot, but the freezer seems to still be working. And this has been going on for over a month now. I had to throut out 300 worth of food.
  • Ken Bledsoe May 11, 2010
    When you open the freezer do you hear a fan running inside the compartment?
  • 76 Answers
You have a defrost problem, or your evaporator motor has stopped working.if you have ice build-up on the back of the freezer, you have a bad heater, defrost thermostat, or a bad timer
Posted on Jan 03, 2009
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
My Miele fridge freezer KFN8762SDED has a problem in the fridge section. The temperature varies between 4 and 13 degrees. If I put on the super chill the temp comes down to normal, 4 degrees only to rise...
Hi Jean, Sorry I have no solution - but have an identical issue with my Miele fridge freezer... - In case you have managed to find a solution, I would be grateful if you could let me know what it is, to save me from running around... ?? Best wishes in any case, Guy
Jan 12, 2011 | Miele KFN8762SDED Bottom Freezer...
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Mar 08, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridgefreezer top fridge section has stopped
see if the back panel inside the refr comes off if it does and u have a fan back there make sure it is working if not make sure its gettin power to it and if it is and not running then replace it and see if this corrects the problem if this fails see if u have a duct going from the freezer to the refr if u do take it apart and see if somethings blocking the airflow or if it has a door thats stuck shut and not letting air go thru
Mar 01, 2010 | Refrigerators
RS21DABB- water dispenser will not dispense anymore. Mechanically intact but no flow! Rest of fridge/freezer perfect!
no water can be the early signs of the common issues with samsung rs21 models
what happens is the fridge cooler /defrost system goes faulty and freezers the water instead of chilling it , the best way to check is to take the 2 drawers out the bottom section of the fridge you will then be able to see the water bottle , if there's a lot of ice around the bottle then this would confirm a defrost issue , you can heat the bottle for 10 minutes or so with a hair dryer etc , if the water starts to work after this then you probably will have to call an engineer or fit the rs21 diy fridge repair kit
this video may help
Dec 17, 2009 | Cell Phones
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
