Question about Linksys Wireless-G WRT54GS Router (e125894)
Not prompted for network security key
I have router security set to WPA Personal. On my laptop when I select my network from available wireless networks I am not prompted for security key. If I highlight the network and use change advance settings, the network shows up as network authentication open and data encryption WEP. I'm using Win XP Pro SP3. I have another laptop and a desktop with wireless adapter that both connect just fine. Any suggestions?
  • burtap Jan 01, 2009
    When I change the settings and enter the passphrase I get a bubble that shows limited connectivity, which fairly quickly changes to unable to connect. The wireless network connection status dialogue box, under support tab, shows Invalid IP Address.
    Burt
    Thanks, Chris. I think I'm genetically incapable of letting this thing go with the WPA. I'm sure I could connect with WEP, and I doubt I need much security, but it's the principle. This all started when I replaced my WRT54G with a WRT54G2 (it's not an "S" so I guess I'm in the wrong forum). The laptop worked fine using WPA with the old router.
    Burt
  • 827 Answers
You could try just typing in www.routerlogin.com and entering your router password.. (my default is 'admin' for user and 'password' for password) and then go into the Wireless section, or the Security section and enable WEP with whatever password you will remember easily.
If in doubt, you can Restore Factory Settings and that'll clear any encryption or MAC filtering you might have set up, then you can start with a clean slate, and enter your new router username/passcode and your wireless encryption password and write it down somewhere safe!
Chris (ziraffa)
Posted on Jan 01, 2009
    Problem Solver:
  • 6 Answers
Sir,
Under 'preffered networks', which can be found on the Wireless networls TAB in advanced settings, you will see your network there. Click on it and then hit properties. Under the 'Association' TAB, you will see network authentication, choose WPA-PSK or WPA, but I will imagine that your key is a Pre-shared key. Enter it there. Data encryption will be TKIP and not AES. Go to connection TAB, and make sure the box is checked in that section. If these steps fail, then you can always change your encryption to WEP. You can do this using a computer which connects to your internet through the WPA key. Once connected on that PC, open up command prompy using the command cmd in the RUN box when you click on the START TAB. A black box will open, simply type ipconfig and look for "default gateway"...it will have a number with a few dots, like this one: 192.168.1.254.....etc. Enter this code into your internet browser search bar, and hit enter. Your internet providers interface will show up, you can find a tab which will have something to do with wireless security, and there you can change the WPA to WEP, with a WEP key of your choice. If you are prompted for a password then you should know it! Sometimes, the usernames can be simply 'admin'. If you manage to change your security to WEP, you can use your laptop!
All the best.
I dont know what my network key is.
open new Internet Explorer and type in address Bar " http://192.168.1.1" and hit enter.
Leave user name field blank and type "admin" for the password.If you changed the router password, then log in using your password to login to the router.
Once you are in the router setup page, click on the Wireless Tab at the very top of the page. Once you are in the Wireless Tab, just right under the word Wireless you click the sub tab that Wireless Security. On this page you will see the Security Mode. If your security mode is set to WEP you will have four sets of keys available. To known which key to use look for the Default Transmit (Tx) Key, If your default transmit key is set to 1, then you will use the key in Network key 1 to connect to the wireless network. Now if your Security mode is set to WPA (Personal/Pres-Shared Key/PSK) what's inside the WPA-shared key or Pass phrase / Personal Key box is the network key for your wireless network.
May 15, 2011 | Linksys Wireless-G WRT54G Router
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Thanks
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
Upluged router to move it and lost "Secure"
Welcome to fixya
Please follow the steps to make the wireless network private
http://192.168.1.1
Thanks
Vote me if you find my suggestion helpful
Apr 25, 2011 | Linksys Wireless-G WRT54G Router
Have a router but not software for linksys, have reset the router but don;t know how to put in new password
Welcome to fixya
No proplem you don't need a software cd to secure the router. Please follow the steps
http://192.168.1.1
Thanks
Vote me If it helps
Feb 07, 2011 | Linksys Wireless-G WRT54GS Router...
Need to set up a pass word on my router
http://192.168.1.1
Thanks
Vote me If it helps
Feb 01, 2011 | Linksys Wireless-G WRT54GS Router...
Hi i have installed my router over a year ago now but am wondering how i set up security as others in my area can pick up my network easily without any passwords and it is slowing my computer down thanks.
In general, you can follow the basic steps below.
I would recomend using WPA2 or WPA secutity over WEP. (as this is a stronger type of wireless security)
- Open a web browser on the computer.
- In the address bar of the web browser, type http://192.168.2.1 (default router ip address, you may have changed this)
- Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit. (if you have already set up a password to login to the router then enter it here)
- Click on Security in the left-hand column under the Wireless heading.
- Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
- Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
- Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
*NOTE* Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
= Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
If you need assistance with how to re-configure your computers, then please provide the version of windows that you are using.
Basic steps are:
-Disable the current Wireless Connection
-Enable the Wireless Connection
-Search for available wireless networks (look for your SSID wireless network name)
-you will be prompted to enter in your PSK and then save your settings
Jan 03, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setting up security WPA
Hi Friend,
In order to resolve the issue please follow the steps:
1.Connect the router to the computer and turn it on.
2.Type 192.168.1.1 in the address bar of the Internet explorer and hot enter.
3.Enter the Username and Password (default password is admin and leave blank the username section)
4.Click Wireless tab and fill the sections as mentioned:
Wireless Network Mode-Mixed
Wireless Network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID-Enable and click Save settings
5.Now click Wireless Security tab.
6.Select the Security Mode as WPA Personal
7.WPA Algorithm-TKIP
8.WPA shared key- Enter a key/password of 8 to63 digit length
9.Group Key Renewal-3600 and click Save settings
Turn off the router for 30 seconds and turn it on after that.
Now your network is secured with WPA Personal key.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
Need to set up wep or wpa key
Hi, this link I provided to you is useful for you.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3696
Jan 11, 2010 | Linksys Wireless-G WRTP54G Router
I got new laptop and i want to conect with wireles but is asking for security key which i dont know where to check to find it. How can i do it/
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router’s web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router’s password ("admin" is the default password), then click OK.
To setup or SEE the WPA Wireless Security on your Linksys router, follow the steps below:
Setting-Up the Wireless Router to Use WPA
Step 1:
Access the router’s web-based setup page. For instructions, see above
Step 2:
When the router’s web-based, setup page appears, click Wireless and select Wireless Security.
Step 3:
Select WPA Personal under the Security Mode drop-down menu.
NOTE: IF YOU ARE JUST CHECKING ON THE PASSWORD NO NEED TO GO ON JUST TAKE NOTE OF THE WPA SHARED KEY AND USE IT IN YOUR LAPTOP WHEN ASKED OF THE PASSKEY
Step 4:
Select TKIP on WPA Algorithms.
Step 5:
Enter your desired WPA Key on the WPA Shared Key field such as “MySecretKey.” This will serve as your network key whenever you connect to your wireless network.
NOTE: Do not give this key to anyone. This key will secure your wireless network. Leave Group Key Renewal to 3600 seconds
Step 6:
Click 3695-017.png.
If you need further assistance please do not hesitate to contact me....GOOD LUCK!!!
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
170 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
