Question about Jandy AQUALINK RS TELELINK KIT
My inside control panel turns things off/on automatic.
Example when I turn on the heater at my inside control panel, it will stay on a while and then cut off. If I go outside and put unit on service and then turn heater on it works ok.
Sometimes the booster pump turns on by itself.
    Novelist:
  • 163 Answers
There is some wire get short.
Posted on Jan 01, 2009
  • ronny2051 Jan 01, 2009
    Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
    Repalce the button or disconnect it at the outdoor panel.
How to light my heater? I can't fine the pilot.
It appears the pilot is behind the metal thing with two holes on it. Can't tell what the holes are but they look like viewer holes. You can follow the main hose and see where it goes to the control dial. From there you can see a smaller metal line that goes from the dial area to behind the metal thing I'm speaking of. Also there is a skinny brass line which is your temperature sensor which the tip is real close to where the pilot area is. You should be able to push down on the automatic igniter and see a spark. That's where your pilot light is which is a good indicator as well. You may have to hold down the igniter for a minute or two to make sure the pilot does stay lit. When you do find the pilot and the pilot does not stay lit you may have to buy a new thermal coupler. Best of luck to you.
Nov 11, 2012 | Kitchen Ranges
The difference between thermal fuse and thermostat
Thermal fuse is a heat-sensitive safety feature that shuts down system when overheating is detected.
In electrical wiring, the thermal fuse reacts to high temperature caused by too many amps on the electric circuit. When temperature exceeds the fuse amp rating, then the fuse trips and cuts power to electric circuit.
Example of thermal fuse is a household circuit breaker.
Gas water heaters have a different type of thermal fuse located in the combustion chamber or on the combustion chamber door, and also inside a copper probe inside water tank. Water heater thermal fuses will trip when water temperature exceeds fuse rating, or when heat inside the combustion chamber exceeds temperature rating of fuse. This action will cut off gas supply to water heater.
So a thermal fuse is a safety feature.
Thermostat is not a safety feature.
Thermostat is a measuring tool.
Thermostats measure temperature.
Example of thermostat is outdoor thermometer, or cooking thermometer, or Heat-AC control located on wall inside house.
Thermostats can give a simple temperature reading, or they can cause a separate control to turn on-off depending on application.
For example thermostat on Heat-AC will read room temperature, and when temperature exceeds setting, this triggers a switch that turns Heat-AC on-off.
Many appliances have both thermal safety fuse and thermostat.
Take for example a gas water heater. A copper tube extends into the water tank. Inside the copper tube are 2 things: A thermostat probe to measure water temperature, and a thermal fuse called an ECO for energy cut off. The ECO is a thermal fuse, and is a safety feature.
http://waterheatertimer.org/images/Gas-valve-ECO2-358.jpg
The thermostat reads temperature of water, and turns water heater on-off to keep water hot. A person can adjust water temperature by adjusting the thermostat dial on front of water heater.
However if the thermostat fails, or some other problem occurs, and water inside the tank gets hotter than 180 degrees, then the ECO or thermal fuse will trip. When the thermal fuse trips, this turns off gas to the water heater so water cannot get any hotter. The safety device prevents water heater explosion. The water heater must be repaired since this particular thermal fuse cannot be re-used afterwards, and must be replaced.
Oct 11, 2012 | Dryers
Difference between thermostat and thermal fuse
Hello Mary
Rinnai reh15-217 burners cut out automatically after being on for about 1/2 an hour
If you're saying the burners turn OFF after 1/2 hour, but the pilot light stays lit ... I'd have to assume that the automatic thermostat control on the heater, turned the burners OFF, because the temperature you had it set on had been reached. The real question (at least for me) is are you allowing enough time for the temperature to drop and the heater to turn back ON automatically?
May 16, 2011 | Heating & Cooling
Why do I have to press the remote control several times (between 6 and 12) to get the gas heater to turn on? And when the temperature reaches the set point and turns off heater, it will not go back on...
The first thing I would do is make sure that your batteries are in good shape and that connection in the remote and baterry ends are clean.
You can easily clean the ends on your batteries by rubbing them briskly on a piece of denim or other semi rough cloth and use a fine grade of sandpaper to clean connections inside the remote. Thank you
Jan 06, 2011 | Desa International GWN30T GLOWARM® Gas...
Asko D1776 - Heating element stays on after the cycle has ended. I have to turn off at breaker panel to shut down. What part controls this heating element?
Welcome to FixYa.
Based on your description it is likely a faulty control board, unfortunately. Here's what you can do to check...
**Turn off any power to the unit...safety first**
You'll need to access the control, this is best done by way of removing the front panel, i.e.
Once to this point, identify the wires on contact PF2 and inspect the closest relay to it, which will be K1.
If you are capable, measure amperage from PF2 when the unit is idle there shouldn't be power present, you'll require an ammeter.
Having said all that, it may be obvious when you visually inspect the control, if it's burnt up or if the relay looks burnt inside.
This is an example of a damaged control but it may not be as extreme with a heater relay defective...
Let me know what you find and I'll try to help you further if necessary. For the control should be available at "repairclinic.com"...but if not let me know I may have one left.
Good luck and thanks for choosing FixYa.
Regards,
Macmarkus :)
Nov 16, 2010 | Asko D1776 Stainless Steel Built-in...
OUR 04 TRAILBLAZER, THE A/C STOPPED WORKING, IT WOULD WORK SOMETIMES AND BLOW COLD AIR NOW NOTHING COMES OUT, OR THE HEATER TOO.. LITTLE AIR WILL PULL THROUGH IF ON THE HIGHWAY, I CAN HEAR IT CLICK OVER...
a couple of things,1 blower motor fuse.2 blower motor gone out.3 switch on fan speed control switch not sending signal to fans.after checking the fuses.next check theswitch on control panel.set ac or heater.if fan still doesnt come on then replace it.when it work and then stops working there are a lot of possiblities that caused the prob relay too not fliping over inside staying close loop.hope this helps.
Aug 16, 2010 | 2004 Chevrolet TrailBlazer
2001 silverado, 5.3L. heater control stays hot,
I have the same problem, I think the door inside the heater box gets stuck when you turn it to hottest setting. Try going 1/2 or 3/4 to hot and see if it recovers without turning off the truck.
Feb 20, 2010 | 2001 GMC Sierra C/K3500
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Won't stay on
mso 9]> Normal 0 mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> Warning this will disable the tip over sensor, Unit will not automatically turn off when knocked over!!
I had the same problem with the "F" appearing and the unit turning off. I read a similar post about the hz-709, that talks of removing the "tip over sensor". To remove the sensor, "two little black boxes on one chip, that rattles like there is a ball bearing in each box."
Remove two small screws on the bottom of the heater then remove two small screws on the top of the heater "top screws are under a small cap that can be popped of with a flat head screwdriver."
Inside long panel front Unplug three wires, White Brown Blue "remember where they where plugged in, so you can plug then back in later."
Inside long panel front there is a silver panel with eight screws on it only the, only the four "corner" screws have to be removed to remove silver panel.
remove silver panel then remove remaining 4 screws, Now remove front control from long panel front, there are 6 screws only have to remove the four inner screws, Open white box, slip large chip off three prongs,
there are two small blue wires connecting to the two small black boxes from the beginning of this post, cut wire from box, twist or solder together, and tape with electrical tape.
"You have just removed/disable the tip over sensor, Unit will not turn off when knocked over!!"
Reverse steps reassemble the unit and enjoy.
Feb 04, 2007 | Honeywell HZ-710 Oil Filled Radiator...
Jandy AQUALINK RS TELELINK KIT  Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
