My car stereo has a cable coming out the back which I assume is to plug my ipod into. I tried plugging it in with the same cable that i use to plug it in to my cd player at home but i can't work out how to make it play. I can't find an 'aux' setting on the car stereo despite having pressed every button! Can anyone help?
According to
http://www.jvcmobile.co.uk/documents/installation_manuals/KD-G312_311.pdf
that's a cable for the steering wheel remote even though it looks just the same as an aux in
SOURCE: got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
SOURCE: Ipod Connection on JVC KD-S550 CD Player
hi, most of the slots that plays the ipod is in front of the head unit panel, if you dont find any slots in front then it will be nowhere at the back for it will be hard to access. hope this helps, have a nice day
SOURCE: connect ipod to cd player wit built in aux input.
solution to ipod problem some ipods do not work in directly with after market sterios some do now a good solution is to go to your local radio shack buy the rca jack one end proper male femal connectors on one end then head phone jack on the other this will play anything its just like the old days when you had to buy that clunky tape with head phone jack attachted it works all the time make sure ipod is powered so that it wont loose power while playing its kinda old school stuff but works since most ipod products dont work with aftermarket sterios
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
SOURCE: How can i turn the aux option on on my jvc kd-g801
it's not for running your ipod or whatever else, it's for steering wheel control for those cars that have the feature. that's what it says in the manual anyway, there's gotta be a way to run the ipod through though for sure
