Question about Refrigerators
Refrigerator runs almost all day
Amana bottom freezer BR22TL runs all day. Will shut off during night for short period. Had vegetables frozen in lower drawer recently. Cleaned out bottom coils and behind
    Scholar:
  • 58 Answers
Your refer will run about 85% of the time, But if your refer items are freezing i would recommend you replace the refer t-stat. The only time your unit will shut down is when it's in a defrost ( about every 8 hours for 30 Min's or less ) and by your t-stat when it reaches temp, if you have it set to a warmer setting and it's freezing you items then for sure you have a bad t-stat. Hope this helps you
Posted on Jan 08, 2009
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
My Amana BR22TL the freezer is not freezing - it stays cold but does not freeze. Model has the freezer on the bottom
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | Amana Refrigerators
Motor still running after gasket replacement
it will take at least 24 hours for the freezer to settle down to the correct temp -18c.the water is the frozen condensate that builds up inside the outer door over a period of time and should be allowed to drain away when you do a full 48hour defrost once a year....frost free means frost free where there is an air flow.....
Jul 21, 2010 | Amana ABB1927DE Bottom Freezer...
There is a leak that periodically happen in the lower left hand corner of the freezer. about every two days. what does this and how do I fix it?
The defrost drain is frozen shut.
Turn off the refrigerator.
Remove the lower freezer bins to access the drain opening.
It is on the back wall of the freezer about 8 inches up from the bottom.
Chip out visible ice.
Use a hair dryer to melt the ice in the drain hole.
Jul 11, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ther is water is building up in the refrigerator and freezer
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 09, 2009 | Amana ARB8057CSL Bottom Freezer...
Water weeping out vents in lower back of freezer compartment
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Vegetables frozen in vegetabe drawer
your refrigerator door (ajar) check coldcontrol
Mar 01, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frigidaire FRS26r4cw3. frozen on the vegetable section
the coldcontrol check to see if your doors closing it may be (ajar)
Jan 05, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
