Question about Casio FX300S-TP Calculator
Calculator Hey, when i type a simple or difucuilt calculation the answe comes up but with a .0 at the end eg. 10+10=20 (supposed to come up) 10+10=20.0 (comes up) Please help i have a very inportant exam in 2 days please.
  • Casio Master
  • 8,073 Answers
Ii has to do with the number of decimals you decided to keep.
If you only handle addition, multiplication and subtraction of whole (integer) numbers you will not suffer from the lack of decimals. But if you divide integer numbers more often than not you will have decimal numbers ex. 1/2=0.5, 1/3=0.333333333etc. If you forbid the calculator to show decimals the first one above will be 1, and the second will be 0.
My advice: ignore the zeros that come after the decimal mark. They will not hurt you if YOU NEVER DIVIDE.
Hope it helps.
Posted on Sep 13, 2009
Posted on May 10, 2007
If i type 10+10 it comes up with 10+10=20 and my setting is on Math G . So mabey try that ?
How to find the determinant by Sharp ELW516 Scientific Calculator
Press the MODE key. and press 4 for MATRIX.
To enter a matrix press the MATH button and choose 2 for EDIT. Determine the size of your matrix by typing in the row x column value (maximum 4). Then press =. Type in the values in your matrix. After each value press = to move to the next part of the table. Once your matrix is complete press ON and then the MATH button. This time choose 4 for STORE. Select the matrix name you would like to store your matrix in - for example choose 0 for matA. Now press MATH and press the down arrow key once. Select 6 for CALC and choose 0 for det (determinant). Then input the matrix you want the determinant of by pressing MATH and 1 for MATRIX. Select the matrix you would like to work with eg, matA and press then press =.
Aug 22, 2012 | Sharp ELW516 Scientific Calculator
$400{(1-(1+.019/12)^-60 / .019/12 I am trying to enter this equation on my TI 30XS calculator and keep getting a syntex error
The problem should be 400((1-(1+.019/12)^-60)/(.019/12))
You can enter it almost exactly as given:
4 0 0 * ( ( 1 - ( 1 + . 0 1 9 / 1 2 ) ^ 6 0 (-) ) / ( . 0 1 9 / 1 2 ) ) ENTER
Make sure you use (-) instead of - to enter the negative number.
Feb 28, 2012 | Office Equipment & Supplies
Rref for 4X4 matrix does not answer correctly
To make sure that the calculator is misbehaving, I suggest that you create a simple 4X4 matrix, that is not singular, and calculate it reduced row echelon form by hand, then use the calculator to perform the reduction. You can also generate a random 4x4 matrix and calculate the rref forms by hand and with the calculator. If the calculator is defective, try to upgrade the OS. If it is still defective, well, the deck is stacked aaginst you. It may then be time to get another one or to send it for repairs.
Jan 18, 2012 | Texas Instruments Office Equipment &...
I am using a TI-84 Plus graphical calculator. How do I use my GC (plysmlt2) to solve a derivative? eg. d/dx(x^6+x^4)=0
There is a command called nDeriv( which you find in the catalog. To open the catalog of commands press [SHIFT][0] (CATALOG), then scroll down or press N to jump to the 1st command starting with N.
Highlight the command then press ENTER. The command echoes on the main screen. Type in the function you want to differentiate, type in a comma to separate, type the name of the vatriable (X), then type in the value at which the derivative is to be evaluated. Close the right parenthesis, then press ENTER.
This is what you see with the newer OS that has MathPrint
With the newer OS with MODE set to Classic, here is what you see.
Hope it helps.
Dec 08, 2011 | Texas Instruments TI-84 Plus Silver...
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
Jun 24, 2010 | Canon P170-DH Calculator
Howdo you get the HP 30s calculator to give answers in exopnential notation?
I hope that this screen capture from the HP 30s manual answes your questions
Aug 19, 2009 | HP 30s Calculator
I have a lot of numbers on the starting and ending points
Regardless of the way it looks, this huge number is just 1, written in scientific notation, with 9 decimal digits. This is due to the configuration of your calculator.
To revert to the default display mode, press [SHIFT][MODE][6:Fix] and select a number of decimal digits between 0 and 9.
If you do not like the [MathIO] (fractions, radicals) you can use the [SHIFT][MODE][2:LineIO]
Hope it helps.
Jun 03, 2009 | Casio fx-300ES Calculator
How do i get the answer of a simple arithmetic in decimals?
There is a button there that says "S<=>D". Compute it first and when the result is in fraction, press this and it will be in decimals. This button is just above the DEL button.
May 12, 2009 | Casio FX-115ES Scientific Calculator
No decimal on my calculator
i want to create a simple calculator using (0-9. add, subtract, multiply, divition, dot, equals ) this keys can u tell me which code i use to create this type of calculator.
Apr 07, 2009 | Office Equipment & Supplies
Casio FX300S-TP Calculator Logo
127 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
