Question about Hotpoint First Edition WMA20 Front Load Washer
Wachine machine is only draining on K cycle
The wachine machine is only working properly on K cycle (short wash). On all othere cycles teh wachine machine won;t drain at all. Also the container where I put wachine powder in fills up with water and doesn't drain. Any advice is welcome, thank-you
  • Anonymous Mar 30, 2014
    Water in machine
We have a Siemens A 08-16 front loader waching machine which doesnt appear to be emptying after its cycle. Any ideas about what the problem might be? Is it likly to be a blockage in the pipe?
Thanks
Posted on Jan 06, 2008
Putting drive belt back on which has come off
Posted on Jul 31, 2007
Kenmore elite washer
Your pump may have something in it not allowing it to drain properly. If this is the case the machine will not do its spin cycle
Mar 16, 2014 | Washing Machines
Washer control humming
it's always worth replacing the brushes - pattern one's are cheap at around 20 quid so it's just about the cheapest thing to try and washing machines do all mannor of crazy things you wouldn't think were related - like not draining (the water does still drain out but when it hasn't spun properly the clothes are still full of water for instance) worn brushes have a differing effect on difrent washing cycles. the other thing to suspect is the controller -but these are so expensive you can nearly always buy a cheap washing machine for less
Oct 02, 2012 | Whirlpool Washing Machines
Cycle not working properly
Hi.
When problem is in the spin part of the cycle it is usually because of either drain filter blockage, siphoning because of incorrect setting of the drain hose at the back, or because of a defective pressure switch.
Check the drain filter, check the setting of the drain hose at the back; clean the rubber hose attached to the pressure switch and eventually replace the pressure switch.
Most washers hide a copy of the service tech sheet inside the control panel assembly, tucked in a sealed envelope. If you retrieve the tech sheet you can also run the diagnostic cycle illustrated in the document.
Regards.
Ginko
Dec 15, 2011 | Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Wachine machine bangs when on spin cycle.
Unless your top loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 15, 2008 | Washing Machines
Drain & Spin issue
Have you checked your water pump? Sometimes this is an issue of the strainer being plugged as well. Do you get any flashing error messages on teh screen?
Jan 14, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Spinning
The reason why it aint spinning is because it is not draining. All new washing machines have what you call a pressure switch that can tell if water is present in the machine.. if present it will not spin.
your problem is either you have a blockage in your filter (5 min job) or you drain pump is not working properly
hope this helps merry christmas
Dec 24, 2007 | Neff W4380X1 Front Load Washer
Hotpoint First Edition WMA20 Front Load Washer Logo
175 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
