Question about Indesit W 123 Front Load Washer
Diplomat apd8703 filling problems
My diplomat apd8703 over filled and flooded yesterday, this morning the machine would not fill and as a result burnt out the heating element, i have disconnected the pipe for the level sensor blown through it and reconnected it, now the machine fills correctly ( although the heater element is gone ) the worrying part now is that i did not find a blockage in the level sensor pipe and cannot understand what i have done to fix the problem, could what i have done have solved the problem or should i look further ?
  • Indesit Master
  • 3,463 Answers
If I were u, I wud check the hose or chamber where the water level switch hose is terminated for any blockage or obstruction there as this is often the cause of the prob, u were certainly on the right track.
Plz rate my solution, and feel free to leave a comment.
Thanks.
Posted on Jan 01, 2009
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
First became aware there was a problem when machine overfilled resulting inj flooding,cold water fill would stop when i turned on a tap ,suspected water pessure switch.new water pressure switch fitted...
If it works O.K. in a different wash cycle, then the timer could well be the issue.
Using that last cycle you described, will it perform a complete normal cycle ???
Jan 05, 2010 | Washing Machines
Washer over fills and floods the floor
Morning. There is a Water fill level switch in your unit that monitors the level of the fill process. this switch is malfunctioning and, it will need to be replaced asap if possible.
Jun 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine overflowing
fill valve may be hanging open and can be very intermitant may be switch but ck valve first start water entering machine shut washer off and notice if valve takes extra time to shut off if it does would suspect valve problem
Jul 02, 2008 | Washing Machines
Dishwasher filling
check to see if you have anything plugged
Mar 26, 2008 | Dishwashers
Washer fills till flooded
change the fill valve located where the hoses hook up
Dec 29, 2007 | Washing Machines
Washing Machine Wont Fill and cycles unresponsive, Help :/
Sounds like your control board is shot. Do you have 120VAC going into it?
Oct 30, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
82 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
