Question about Magic Chef 31000 Gas Kitchen Range
Gas oven alarming and flashing F8
My magic chef gas oven keeps alarming and flashes F8. Tried to stop it , but only thing that does is the off button. when I turn it on again, it does it again when it reaches certain temps.
  • 794 Answers
Hi wlfwoman2002,
The F8 failure code description is an Analog / Digital problem. To resove this error code, please replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using Fixya.
Posted on Sep 19, 2011
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Nov 20, 2010 | Magic Chef Kitchen Ranges
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef beeping
You need to replace the touchpad. I'm just getting ready to replace mine for the second time in 14 years. A bit pricey but not a hard repair to make.
An appliance repairman told me that it's possible to peel the old pad off and carefully fish the connecting wire out to the point where it plugs together. This would save removing the burners and the stovetop I'm going to give it a try when mine arrives
Mar 01, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef super capacity range.
oven takes to long to heat, broiler works fine, even the clock works it's just not heating fast....the bottom lights up,but not the top?
Nov 07, 2007 | Magic Chef 31100 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
130 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
