Question about Sony VAIO VGN-FJ270/B Notebook
Key clip came off, how do i get it back on? - Sony VAIO VGN-FJ270/B Notebook
The "f" key broke.when we press the key the type bar will not go up and make the letter
Take a paper clip and bend a 90 degree bend at the end. See if you can pull the f key back up, then depress the f key and see if the letter comes up. If you pull the key up, and push it back down, sometimes this will cure sluggish (gummy) keys.
It is possible that the spring under the key is broken, but look for staples, paper clips, etc under the key.
If you take 2 paper clips bent at 90 degrees at the tip, you should be able to CAREFULLY remove the f key top (one paper clip at each side wiggling it up side to side) and be able to see under the key.
Also, try this: Take contact cleaner (NOT WD40! It will kill electronic circuits!) and spray the key. If it is gummy, (sluggish) you should be able to restore free motion.
If the spring is broken, take apart a ball point pen, remove the spring, and put it around the shaft of the key, put the key back and, and hopefully it will push the key back up.
But try the spray contact cleaner first. You can get some from Radio Shack (or at least you used to be able to...)
Jul 02, 2014 | Brother GX-6750 Typewriter
Hi, my key fell out off of my keyboard how do i fix it?
A laptop "key" generally comes with a metal harness as well. Just clip the harness onto the back of the key, then press the key onto the keyboard firmly - it should snap back on. If the key looks as if its not clipped in correctly, push down with a little more force and a bit of a finger jiggle.
My son when he was 2 pulled ALL of my laptop keys off - and this was how i got them back on.
Aug 04, 2011 | Computers & Internet
My 3 y/o knocked keys off the laptop keyboard. How do I reattach? Only the key face cameoff the plastic clip is still in place.
If the clips are still in place then place the key over the clip align the key cap so it is in line with the other keys and press down on the key cap until it clicks onto the clips.
Jun 23, 2010 | Acer Aspire 7720 Notebook
Key fell off.
Hi , Just clip the key back in where its supose to, the clip should fit rite back in , i take my keys out often to clean them...
Hope you come right ,
happy new year
Jan 04, 2010 | Logitech Internet 350 USB Keyboard
Key came off
Try www.laptoprepair101.com
Jan 03, 2009 | Sony VAIO VGN-FJ270/B Notebook
My 2 key on the numpad of my acer aspire 9300 has broken off how can i put it back on
Look to see if the small rings or squares under the key are intact. You can carefully with a sharp item lift off another key cap, they usually just un clip and lift off. Don't pry to hard if it doesn't come off easily so you don't break another one. If it comes off with the clips still on the keyboard, examine how they are positioned, see if your #2 keys clips are not separated or broken. Separated, you usually can compare to the other key cap you removed and if not broken it might only require a small adjustment, then just snap it back on. Key boards are different but it would be ideal to find a spare or broken keyboard you can use to replace the clip if broken. If it just won't snap back on, you can use "sticky tack" or even a small piece of gum!
Jul 27, 2008 | Acer Computers & Internet
Keyboard help
Putting the keycap back on is usually fairly easy. Many will snap back into place if you place the keycap back into the correct position and gently press it down. Look on the back side of the loose keycap and see if it has 4 small clips or if it has 2 clips and 2 slots. The one wit 4 clips should snap back on. The one with 2 slots requires you to get one side of the key hinge into the slots before pressing it down onto the other 2 clips.
If only some of the keys stopped working, that usually indicates a defective keyboard. Try connecting an external USB keyboard to see if all the characters work correctly. If the external keyboard works but the laptop keyboard does not, then you will probably need to replace the laptop keyboard.
Jun 12, 2008 | Everex StepNote NC1500 Notebook
Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Keycaps
to get the key back on u will see a metal clip on the underside of the button, kinda hard to explain but easy. take the metal clip and put it in the small clips on the laptop then press the key kinda hard and it will clip into place.. Hope you get it John
Aug 27, 2006 | Dell Inspiron 9300 PC Notebook
Key fell off
hi the metal clips are those wich holds the key in place u need them to be pushed agianst the movment of the key soo they will keep the key in "their hands" grab a big set of tweezers and push the clips separate then push the key to its place (in the right direction) check very closely so the key inserts its place a couple of tries and you will success to do it good luck
Mar 20, 2006 | Compaq Presario 2575US Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
