Question about Samsung TXN2034F 20" TV
High pitched squeal
From my 5 year old samsung txn2034f tv? Any solutions? It squeals intermittently - sometimes months will go by without this problem. Right now, it's driving me crazy!
Thanks.
  • Samsung Master
  • 8,457 Answers
It ur high voltage transformer,the FBT flyback transformer have a paper clip 5"steal,the high voltage go throught it,that where the hight pitch came from,put some Super Glue on all the gaps paper clip like steel,should stop the high pitch when on long time.The big block of plastic with a red wire with a to CRT(CRT tube) that the FBT.
Posted on Oct 10, 2009
    Genius:
  • 1,175 Answers
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Posted on Jan 01, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
My set has deveolped an intermittent high pitch squeal.
It always nice when the high-voltage circuit gives you fair warning of impending doom. Have the high-voltage (flyback) transformer replaced now before it fails catastrophically and wipes out other stuff with it. There are other things that could make noise too, same advice applies to them.
Hope ya fix it!
Jan 03, 2008 | Toshiba 36AF43 36" TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
High pitched squeal from TV
Get a small wood/plastic stick and touch the different coils/transformers to see which one is the cause. Replace part or if the part doesn't run hot, use a small amount of hot melt to quiet. Don't completely encapsulate in glue, don't want to create any hazards.
Oct 29, 2007 | Samsung TX-R2779H 27" TV
Samsung TXN2034F 20" TV Logo
312 people viewed this question
Henry  Thomas
Henry Thomas
