Question about GE Spectra JBP78 Electric Kitchen Range
Bake element split and oven will not heat. - GE Spectra JBP78 Electric Kitchen Range
I have a GE Spectra JB960 oven. I decided to remove the hidden baking element from the oven when it stopped working. This is what I did:
- Opened the oven door and removed two screws holding down the glass cooktop. The screws are located on the underside of the stovetop lip overhanging the top edge of the oven door.
- Tilted the glass stovetop up and propped it up.
- Left and right are defined facing the front of the stove. I removed three fasteners screwed into the top of the left side panel. One needed a Philips screwdriver, one a torx or star screwdriver, one hex screw needed a 1/4 inch wrench.
- At the back of the stove, I removed hex screws using 1/4 inch wrench, attaching the left side panel
- Pried open the left panel from the back swinging it outwards toward the stove front, hinging it along the stove front edge. *Only opened it a few inches ajar* as the stove front edge is attached by a 1/4 inch hex screw and plastic snap anchors.
- Reached inside between the left side panel and the left side of the oven and unscrewed the 1/4 inch hex screw attaching the bottom front corner of the left side panel to the bottom left corner of the oven.
- With the screw unfastened, I lifted the left panel, aligning the holes on the inside of the left panel with the plastic anchors and removed the left panel.
- Made a note of the wire colors attached to the stove element, I slid the power wires from the heating element.
- Unscrewed the 1/4 inch screw attaching the green ground wire and the three other 1/4 inch screws attaching the metal insulation cover to the left side of the oven.
- Removed the metal insulation cover from the left side of the oven. There is a metal tab toward the oven front that slides into a slot in the metal insulation cover.
- (I put on a breathing mask) Folded up the fiberglass insulation from the bottom edge to expose the hidden baking element terminals at the bottom of the oven. The element terminals are near the oven back-end. A slim metal piece covered from the element terminals to a tab and slot attachment at the front-end of the oven.
  I also saw two rods poking out perpendicular to the left side of the oven, just below the metal piece covering the baking element. One rod is about a third of the way back and the other rod is about two-thirds of the way back from the front of the oven. These thick, black rods are different from the baking element terminals which are thin, broad and silver. You may have to dig around in the insulation to find them.
- Removed two 1/4 inch screws near the baking element terminals using a 1/4 inch socket wrench. Using pliers, I grabbed the two rods and pulled them out, perpendicular from the left side of the oven, like a drawer.
- I detached the metal covering tab and slot attachment at the oven front-end while pulling on these two rods.
- With a bit of wiggling, the hidden baking element slid out from under the left side of the oven.
Posted on Feb 13, 2009
  • infogeek Feb 13, 2009
    Step 8 should read:
    Made a note of the wire colors attached to the baking element, I slid the power wires from the baking element terminals.
    Don't forget to *unplug the oven* before doing anything!
    Sergeant:
  • 311 Answers
Thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Posted on Jan 01, 2009
  • Thomas Malailua
    Thomas Malailua Jan 04, 2009
    i know this can seam petty but i advise you on how to correct your problem and you rated me as thanks for trying.thats discouraging.i can get a little credit from the web site for good rateing and that allows me to make a little pocket money.thanks for trying.
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
  • 29 Answers
SOURCE: ge range electric oven won't heat up
WHEN BAKE CYCLE IS SELECTED?
Posted on Jan 29, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Larger heating element not working on outer
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Apr 21, 2014 | Whirlpool Ovens
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Oven bake element split
sorry the upper element is bad
Jan 22, 2012 | Ovens
Wall oven bake element split
Was there a burning smell before at the time when it heated up slowly?A burning smell suggests there was a (possibly continuous) spark at the splitted place.If it was split earlier then the slower warming up was possibly due to a continuous spark, because then there won't be much energy left for heating.It's like an added resistance.So it could've been there for a while already.
The element just needs to connect again where it splitted and should stay there, then it should work again.
Jan 22, 2012 | Dryers
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
398 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
