Question about Samsung RS2630SH Side by Side Refrigerator
SAMSUNG RS21DCNS hi, i am trying to remove the front cover of the twin cooling system of the refrigerator due to the fans stopping and not cooling the fridge. I have removed all screws and clips but it seem to be fixed in the centre? how does this come free Ian
  • susanL Nov 21, 2007
    I have the same problem. I have access to the fan, and the fan is working. But, seems like something keep shutting off electric to the fan so it doesdn't stay on to keep the fridge cool. Were you able to fix your fan problem. Would appreciate any hint as it's day before Thanksgiving.
  • fridgemagnet Feb 08, 2009
    I have the same problem. The fan works but keeps switching off. Did you mange to fix the problem?
    President:
  • 1,462 Answers
Speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
Posted on May 07, 2007
The fan cover is held in place by the lighting assembly above, so you need to take absolutely everything out before starting. Remove the single screw at the top of the translucent light cover and unclip the cover. Remove the 3 screws now visible. Undo the crome bezel & remove the screw beneath. Unplug the temp sensor/fridge light connectors. Remove the lighting assembly. Unclip the deodoriser compartments & remove the screws. Undo the 2 screws holding the water tank. Undo the 2 screws at the very bottom of the fan cover whicg should now be accessible. The fan and cover can now be teased out. The sealing strip around the bottom can be a bit sticky. I discovered an inch thick layer of ice blocking the fan circulation - apparently the drain hole is too small, but easily adjusted in the polystyrene.
Posted on May 13, 2007
Where is the evaporator fan located in a samsung RF26HFENDSR refridgerator
There are two in this model. This is a twin cool meaning it has 2 evaporators, 2 evap fans. Top fan is behind that panel thst says twin cool. Careful removing the evap cover as its styrofoam behind the plastic. In the freezer its located behind the back panel
Aug 14, 2018 | Samsung Refrigerators
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator section of side by side has stopped cooling, removed coil cover, fan was covered in ice, is there a fuse somewhere for fan
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Samsung Refrigerators
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung rs21dcns fridge freezer Ice build up in fridge - twin cooling fan not working Fridge temp not acheivable
very common issue on samsung r21 models , repair kits available and plenty of help videos out now
have a look at this youtube video and the chanel it belongs to
Nov 10, 2008 | Samsung Refrigerators
SAMSUNG RS21DCNS
The middle part of my refrigrator (RS21DCNS) is full of ice. i have removed ice many times. could you tell me whats the reason and solution of this?
Jan 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dcns
Cant bring up anything on the # u provided
Some refrigerators run  the defrost themostate...
 IF  d. thermostate bad of some frigs fan motor will not run ..
check thermostate for continuity . frig has to be at 20 to 30 degrees to check.. got to be certain temp to close themostate
can cut wires and splice to ..by pass thermostat to check
Oct 01, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge freezer rs21dcns not cooling
press for diagnose the power freece and power cool, you will get an information about the self diagnosis. you can call samsung and will get a clue what is going on. maybe the heating is not working well.
Sep 30, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
446 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
