Question about BenQ MP610 Multimedia Projector
A vertical white line on the projected screen
There is a vertical white line on the procjected imiage. it persists when there is no input and the screen is blanked. the bulb has been changed and the problem is still there.
How did u manage to take it apart?
Posted on Feb 08, 2008
I'm having the same problem some one sugested changing the input tryed s-video and nothing i've taken mine apart and cleaned the color wheel thinking something was bloking light or the image the only thing i havent messed with is the lens area but i'm going to try it i'll let you know if it worked hopefuly someone can help us bcause now i'm stuck with a $300 bulb i hope i dont have to buy another 1
Posted on May 28, 2007
  • jay deleon May 28, 2007
    i got it!!
    i just took the lens off and top p.c.b. and blew it whith an air can and hooked everything back up and wala just like new
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Red Vertical bars cover the right 1/4 of the screen. They starting appearing sporadically several weeks ago and would go away, now they stay on the screen, regardless of video input ..
Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the TV requires service.
Jul 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Samsung hl-r7178w has green video and vert. lines on all analog inputs, hdmi input is good and menu screen is good
Hi,sounds like It could be the DMD board.This is how the DMD board works: http://electronics.howstuffworks.com/dlp1.htm Basically when that Dmd chips starts to fail that's what you'll get color discoloration vertical lines, white spots.You will need to replace the dmd only you can find it on ebay,samsung,or shopjimmy.com God bless you!
Oct 05, 2009 | Samsung Televison & Video
Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
Jul 14, 2008 | InFocus ScreenPlay 61" Rear Projection...
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
BenQ MP610 Multimedia Projector Logo
1,075 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Computer Links
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
