Question about Maytag MSD2732GR Side by Side Refrigerator
Freezer door won't seal
Model # msd2732gr. No obstructions in freezer door. Nothing in the way. But door still doesn't seal
    Sergeant:
  • 311 Answers
You have to be the eyes here.look for tho obvious its not going tobe mysterious.the gasket is magnetic and the magnets dont wear out.look for the point where its stoping it fro closing
Posted on Jan 01, 2009
Why doesn't freezer get cold enough
If the thermostat is turned up and the freezer still remains at around 10 degrees I would suggest the system coolant has leaked or the compressor is faulty. Check that the door seals are not obstructed or broken, that will stop the freezer getting colder.
Sep 01, 2014 | Bosch Freezers
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
I have a Sears Coldspot chest freezer Model #1869. The door doesn't seal properly and ice builds up within the door and the seal becomes even worse. The freezer itself works fine.
A precut seal will be expensive so please don't expect the price to be reasonable should you find one. Sears uses a longer number to list model numbers like 312.215478 as an example. Where can I find my model number? Let me know if you have questions, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Mayrag MSD2732GR freezer door will not close tightly
make sure nothing is blocking door from closing , like food or a basket. if that checks ok there is a cam that on the bottom hinge that may be worn, or you may loosen the top hinge and adjust the door
May 12, 2011 | Refrigerators
Side-by-side freezer door will not close or seal all the way. Nothing obstructing the door/seal.
check the cam gear on the bottom hinge they can break if to much use and or weight
Nov 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
its a visual thing inspect and look for somthing not right[ie..door seal torn,door warped.hinge cam broken.somthing in the way food package wise so door wont close.God bless,tom
Jan 01, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag MSD2732GR Side by Side Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
