Question about Philips 43PP9202 43" Rear Projection Television
NO PIC & NO SOUND ONLY HI PITCH SOUND SURGE FROM BACK
NO PIC & NO SOUND ONLY HI PITCH SQUEEK FROM BACK
  • Philips Master
  • 3,459 Answers
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Posted on Jan 11, 2009
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Windscreen wipers have a high pitch squeek I changed the wiper blades three times. I changed the windsrceen last week, thinking it was some product in the glass. The high pitch squeek continues
Try to run the wiper motor with the wiper arms removed and thnnotice if it is still squeeking. If it is thn you will have to lubricate the wiper shafts especially where the wiper arm fits.
Hope this helps!
Jan 11, 2010 | 2001 Land Rover Range Rover
Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Jun 02, 2009 | GE 24 in. PDW8800J Built-In Dishwasher
Dryer modle #lde9334ace making noise
More than likely it is the belt. A simple fix is to spray some belt dressing on the belt. However, changing the belt would be the best solution. Good luck.
May 18, 2009 | Dryers
Vauxhall vectra squeek.
spray wd40 on it!!!!! or cover it in grease at the top of the rear spring thanks jezza
Apr 05, 2009 | 1997 Acura CL
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Philips 43PP9202 43" Rear Projection Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
