Question about Candy CD623X Free-standing Dishwasher
Dishwasher not washing properly
Water sprinklers do not turn?
  • 247 Answers
Can you provide more information on symptoms: Does machine fill? Does water come out of the spray arms a) at all and b) in convincing quantities (part way through the cycle, switch off, open the door straight away and see what is happening inside). Do you get the same problem if you run the machine without any dishes in? Can the spray arms be turned freely by hand? Knowing the answers to these should help narrow the problem down. A.
Posted on May 07, 2007
Water does not get pumped to the sprayers of my dishwasher
you need to clean out the sprinklers. they do get clogged up with hard water, there is a screw top holding the sprinkler to the pump line. and pull off. put it in some warm water with some vinegar and clean it out.
Nov 07, 2013 | Dishwashers
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    My Maytag dishwasher model MDB7130AWB started making a grinding noise tonight during drain cycle. We just had some work done on the sprinkler system and the water main to the house as well as the check...
    Shut off water to the machine, remove the hoses at the machine and inspect & clean the mesh filters in the water inlets. If dirt did get into the line, it would be from the water main work, not the sprinkler work.
    It doesn't hurt to clean the machine filters.
    However, I would be surprised if that would cause the noise. I think the machine has a mechanical problem.
    Gary
    Sep 12, 2011 | Maytag MDB7130 Dishwasher
    Dishwasher leaves a film of soap on dishes. what needs to be cleaned inside as far as mechanics or is this dishwasher done?
    If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
    Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
    If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
    Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
    1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
    2) Adjust the detergent amount.
    3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
    The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
    Aug 05, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
    My profile dishwasher leaves a film on the glasses.
    Oct 31, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
    How do you know if your dish is working property
    1. water temp must be 120+
    2. soap must not be old
    3. Machine must work as designed
    place a cup upright on the top rack, run a few min. it should have some water in it.
    Usually the spray arms are not turning with that problem. They are designed to turn by water forced out the end of the arm, much like a lawn sprinkler works.If the end holes are clogged, it wont spin. The arms should spin freely.Then check to make sure that the water didn't drain out as fast as it came in. Some D/W have a valve that will get stuck open and the water drains out during the wash cycle..no water, no wash..
    Oct 25, 2009 | Dishwashers
    Doesnt start the eco botton keep staing whith a light
    The small tank of water on left side fills up, but does not come out of the sprinklers to to wash the dishes.
    Feb 08, 2009 | Ariston Technologies LL64WNA Built-in...
    Smeg dishwasher not orking properly
    if water is coming in the drain then you could have a bad check valve. when you open the dw at the end and there was no water it was because you were in the drying cycle and the eement was drying the water as it came in.
    Jan 11, 2009 | Smeg CSU2001 Built-in Dishwasher
    Candy CD623X Free-standing Dishwasher Logo
    142 people viewed this question
    Top Candy Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
