Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Built in flash not popping up
When I attept to take photos in low light or take pictures where the subject is back lit then my built in flash is not popping up instead I get an error 05 message and I have to turn the camera off and back on again. Will I need to get the camera repaired professionaly or is there an easy fix?
  • Andrew Broadhurst May 07, 2007
    Have followed some threads from another forum, and cleaned under the rails of the hotshoe.....the flash pops up now but still comes up with the error 05 message!!
  • 641 Answers
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
Posted on Jul 31, 2007
My Canon Rebel XS will not auto focus correctly. It sounds like it is trying to focus, but only flashes and will not focus or take the picture.
Those quick fast flashes usually mean the camera is trying to find contrast to take the photo but it can't. The scene might be to dark and the camera can not set it's focus and there for cannot take a picture. Move the camera slightly from left to right on the subject and see if it can manage to set focus. It's normal for the camera to give out these quick flashes as it is trying to find some sort of contrast in the subject, turning on a room light might help this?
Now when you manually focus, then the camera does not have to use it's built in auto focus sensor and will let you take a photo when you manually focus on the subject.
Sep 30, 2012 | Canon Rebel XS / Eos 1000D Digital Camera...
Tip
DIY Pop-up Flash Diffuser
Wanting to lessen the power of your flash with under exposing your picture/subject?
Want to add natural light bounce to your subject and lessen shadows?
Wanting to have a pop-up flash diffuser without spending a dime?How about removing shadow cast when doing some macro shots?
If your answer to these questions are YES, then time to read this DIY guide. This should be easy to follow and the material(s) needed should be available in your home.
First, let's briefly discuss what a diffuser is. A diffuser lessens the strong/ harsh light coming from your camera's built-in pop-up flash, creating a softer and distributes the light evenly on your picture.
There are lots of pop up diffusers out there and are relatively cheap. However here's one that I've tried and tested and worked fine for me. Take the cap of your empty roll-on(deo) place it with your hand, right at the front of the pop-up flash(in it's popped out position). Then take a picture using flash. Try it with and w/o the cap to see the difference. Not impressed? Try it first and explore new ways of getting better pictures.
on Mar 23, 2011 | Cameras
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Aug 13, 2017 | Canon EOS 1100D / Rebel T3 Digital Camera
Hi. Hoping you can help with this one ... The built in flash is popping up but the flash light is not working. Thanks, Kylie.
I'm going to say you have set the camera in one of the preset modes for portraiture, macro or something which would automatically pop up the flash. When the camera light sensor reads the light possibly because you have focused on a white dress, shirt or some other bright spot in the scene or subject it doesn't flash due to over exposure. To try this theory try taking a picture in a dimly lit room.
Also you may find better results if you turn the dial to "P" for program and activate the flash manually with the little button. OR be brave and switch the dial to "M" for manual set your aperture at say F8 and your shutter speed at 1/125 pop up the flash and make the shot assuming you are doing a portrait type shot 10 to 12 feet away.
Dec 20, 2010 | Nikon D60 Digital Camera
I use d80 and flash sb 600 on a bracket and when i take a photo when th lights are dim if the subject is close thier lit up but the rest of photo is dark why?
It's the Inverse Square Law. Light drops off as the square of the distance. If an object is twice as far from the light source it only receives a quarter as much light. So, if the subject is lit properly then the background will be dark.
This is a law of physics. However, there are several things you can do about this. One is to move the light source. Another is to have more than one. The D80 can control other flashes, so you can use the D80's pop-up flash to light the subject and the SB-600 (or more than one of them) to light the background. Another possibility is to bounce the flash off a white ceiling or wall to soften and diffuse the light. Another is to use slow-sync, leaving the shutter open longer to let the background illuminate. You can read more about this in the manual.
Jul 14, 2010 | Nikon Speedlight SB-600 TTL Flash
Pentax istd built in flash goes off when taking picture but picture is underexposed but if I use a different flash in manual mode the camera works ok
What distance are the subjects when using the built-in flash?
The built-in flash is optimized for use between 0.7m (2.3ft) and 4m (13ft).
You could also try adjusting the ISO setting (higher ISO requires less light) or adjusting the EV value to a positive number to increase the exposure.
May 14, 2010 | Pentax *ist DL Digital Camera
Help!!!
The best way to avoid red-eye is to have the flash as far away from the lens as possible. If you can mount an external flash onto the flash bracket, use that instead of a built-in or pop-up flash. Similarly, you can use bounce mode to make the light fall on the subject at a different angle/direction from the lens.
Mar 12, 2008 | Cameras
Flash
Just hit the flash mode button until the get the lightning bolt symbol meaning constant flash. I use this all the time on the same camera for a backlit subject when I need a fill flash
Mike
Jan 06, 2008 | Olympus Camedia C-2040 Zoom Digital Camera
Built in Flash stutters...
This is the camera trying to give itself enough light to focus with.
As it uses contrast to focus with you will get problems in low light conditions. There's no way round this I'm afraid except to light the subject better. As it's a digital camera and you're not wasting film, try manual focus and see what results you get.
Nov 02, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
401 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
