Question about Kitchen Ranges
GSP31GER GE gas slide in oven dosent work
Stove top works fine, but oven is completely dead. won't heat at all
  • 1 more comment
  • SalGer Mar 16, 2009
    Sir:
    You may have solved my problem as well. My broiler is not working on my JGSP31GER, gas oven. Neither, upon checking per your advice, is my self-cleaner...though the Bake function works fine. Am I to understand that your suggestion is to replace the "broiler ignitor" and that it is part number WB13K5058? If so, where is this item to be found on the unit and what precautions should I take when doing the replacement?
    Thank you in advance.
    Further to my message, sorry but the self-cleaner seems to be working (as are the stovetop burners) so it is only my broiler that refuses to lite. May I assume that it is the broiler igniter that is faulty or should I be searching elsewhere.
    Thanks again...
  • C MCH Mar 27, 2009
    GE Profile JGsp31gering back burner as a very low flame, how can I fix it?
  • 1,543 Answers
I think you missed a letter at the beginning of your model number. (it is maybe a JGSP31GER ?) I would first test the broil, and see if that works. (I would guess that it does) Most likely the oven ignitor (part number WB13K5058 ) needs to be replaced. It is located under the floor of the oven right next to the burner. It is a round electric coil thing about 4 inches long. If you want to confirm that this part is bad before replacing it, (and the broiler works) you can take the ignitor off the broiler and install it in place of the oven ignitor. They are the same part number. Of course now your broiler and self clean will not work unless you replace the broiler's ignitor. This is not too difficult, maybe a 3 on a scale of 1 - 10. Should be a Fix-Ya for your slide in range!
Posted on Jan 01, 2009
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
305 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
