Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Moving internet to another room
I'm moving the location of my PC. Can i safely unplug 2247NWG-VGX power conncection, DSL connections, etc., all wall conections, then reconnect just as was connected and expect internet to work as it did in original location?
  • 37 Answers
As long as you have an active DSL connection in the new room, yes you should be fine. All settings are saved in the router's flash memory and won't be lost by disconnecting the power. Make careful note of where everything is plugged in (a digital photo is great!) and in the worst case, you can move it all back until you figure out what is wrong.
Posted on Jan 01, 2009
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
HOW TO FORWARD PORTS 8090 AND 37766 TO SPECIFIC IP ADDRESS
Go to this web site and follow the instructions.
These instructions are specifically for your router and a host of different apps you can forward the ports for
http://portforward.com/english/routers/port_forwarding/Netopia/2247NWG-VGx/2247NWG-VGxindex.htm
Jan 18, 2011 | Netopia 2247NWG-VGx Wireless Router...
I need the dns server address for netopia 2247nwg-eir
Connect pc to the the router using ethernet cable. Go to "Run". Type "cmd" (command prompt). In the command prompt, type ipconfig /all then enter. On this point, information in your connection will seen. see picture below.
Mar 28, 2010 | Netopia 2247NWG-VGx Wireless Router...
We have DSL set up through a wireless router, but it is extremely slow. Any suggestions?
Slow connection can be solve by changing the MTU on the router to a value of 1400 and also better do a firmware upgrade on the unit , you can find the latest firmware from Netopia's web site.....
Dec 13, 2009 | Netopia 2247NWG-VGx Wireless Router...
Wireless light is on solid and no wireless connection. Internet connectivity is still possible through wired LAN cable.
These due tend to build up a static discharge and you will need to unplug it for 10 and plug back in to reset it.
Sep 23, 2009 | Netopia 2247NWG-VGx Wireless Router...
I cant find my driver for my netopia 2247nwg wireless router.
You don't need a driver for the router. If you go to the netopia website, they will have directions to allow you to get into the box through your browser with step by step instructions. An alternative is to call your DSL provider. Their tech support should be able to walk you through all the steps. I hope that helps.
Sep 12, 2009 | Netopia 2247NWG-VGx Wireless Router...
A few Questions , need answers
if you can, enable PNP on the router . It will then discover devices that require ports opened and do it automatically.
Jul 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cannot get laptop on the internet.
well you gotta make sure that your laptop is not too far away from the laptop; cause there is a distance cappacity. and try playing around with the antennas, and moving it around. i hope this helps a little!!
May 28, 2009 | Netopia 2247NWG-VGx Wireless Router...
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
