SIR I HAVE DELL 1525 LAPTOP AND WANT TO INSTALL MICROSOFT OFFICE STANDARD 2007 INTO WINDOWS VISTA BUT I HAVE TRY SO MANY PRODUCTS KYE BUT INCORRECT, PLZ GIVE ME CORRECT PRODUCT KYE
Re: SIR I HAVE DELL 1525 LAPTOP AND WANT PRODUCT KYE
You can install microsoft office standard 2007 into windows vista no problem you will find . I really recomend to install microsoft office 2003 because office 2007 is not so easy and frandly
Please Try the following keys for Office 2007:
RW886-RR279-WR769-9X3VD-Q6YYJ
VFPPH-JT36Q-VK23R-RP7BW-CJ8BJ
TB9R6-G8TGC-FGW2D-9DKWR-CQGHW
QMX6G-CGCG9-4DVF7-2R93Y-YFMYJ
J4PP2-948Y7-3D692-GWCXD-HPQQ8
C93YG-DCRBP-R3BGJ-Q288Y-FGPVW
2. Right click on Proof.XML file, select Open With in the right click menu.
3. In the Open With window, select Notepad to be used to open the XML file.
[Note: In Windows Vista, if you can't see the Notepad option, simply double click the "Other Programs" to unhide it.]
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
<optionref Id="neverInstalled"/>
6. Save the Proof.xml file.
[In Windows Vista, you may need to take ownership and grant full
access permission to yourself before able to modify the file. We already
have a detailed article on that. Here is the link to How to take
Ownership of a File in Windows Vista]
Hi, The Inspiron 14 that you have isnot compatible with windows xp, as it needs certain drivers for the hardware that is installed on the computer that are not supported by XP. However you can install windows vista as an operating system and install Office 200. However if you are using the Linux operating system the office 2007 would not be compatible with the same.
The terms of service of FixYa.com prohibit users from engaging in or
encouraging a criminal offense such as software piracy. To obtain a
product key for Microsoft Office Standard 2007, please visit the
company's website at www.microsoft.com or a reseller's website and purchase a copy for yourself.
SInce SharePoint Services 3.0 and SharePoint Server 2007 does require a server interface to run the collaboration tools you are unfortunately stuck with running it on server software. But all is not doom and gloom as there is an option for you to run Microsoft's Virtual PC. Here is an article on how it works from Microsoft. (http://windowshelp.microsoft.com/Windows/en-US/Help/97a74f0e-798d-45ff-b9bf-7feed68c40e51033.mspx) . This allows you to not ony run your native Operating system, but also run SharePoint on th esame machine in a virtual environment.
hi, yes you can install office 2003 while you already have office 2007. you just need to change the installation directory when you launch the setup for office 2003. change it into something apart from what office 2007 already is installed in.
so what you're trying to say is that you should be entitled to an upgrade to office 2007 if office 2003 doesn't work? i would maybe think so... but no solid answer for that one.
