Question about Sony VAIO VGN-FJ270/B Notebook
Key clips my sony vaio vgn fj 270 laptop have the keys falling off. Like to know how those clips underneath it are attached so I can fix it myself
Can sony vgn-fj77gp/b support webcam with windows 7?
refer to the follow page
http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/
Aug 13, 2010 | Sony Port Replicator for Vaio FJ Series
Function key doesn't work, how to fix it?
Install VAIO Event Services (Notebook Utility) and restart the Computer.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170B&upd_id=2002&os_id=7
Jun 25, 2010 | Sony VAIO VGN-FJ170/B Notebook
VAIO VGN-FZ210C/E 15.4" Widescreen Laptop Computer PC Notebook: hello in my laptop i.e.sony vaio vgn-fz210c full o...
It is better to perform the Recovery...
The Computer is having the Recovery Partition in it..
to access it and perform the Recovery..
Restart the Computer, tap the F10 Key...
Then at the "Edit Boot Options" screen, press the Enter Key..
Then, select the VAIO Recovery Center....
further instructions are here..
May 18, 2010 | Sony VAIO VGN-FZ210C/E Notebook
The computer shuts off when the screen is adjusted forward.
The LCD Display Cable Is Most Likely Pinched Or Already Past the Pinching Point and Has Broken Solid Connection, causing the Short and shutdown when screen is moved or flexed...
The Hinge Area (Left Side)... Needs To Be Examined... And If No Short/Pinched/Frayed Cable In That Area, You Need To CHeck The Display Cable Where It Connects To The Back Of THe Screen... Reseat THe Ribbon Cable...
Nov 25, 2009 | Sony VAIO VGN-FJ270/B Notebook
Fan went out. how to repair myself
First you need to find out if you can purchase the fan,
http://www.sparepartswarehouse.com/Sony,Vaio-VGN-FJ-FZ-Series,Laptop,Fans.aspx
Now you need the Vaio VGN-FJ Series Service Manual,
http://tim.id.au/laptops/sony/vgn-fj.pdf
(PDF file download. Advise letting it download all the way, before looking through it)
Now post back if you need me to guide you. Looking at the procedures you need to follow can be daunting, if you've never done this before.
(Me? Oh yeah)
Nov 12, 2009 | Sony VAIO VGN-FJ270/B Notebook
My laptop doesnt detect USB Pen drives (sony vaio VGN-FJ 270)
Go to start->control panel->system->hardware->device manager. Expand Universal Serial Bus controllers. Right click on every USB root hub and select uninstall option. They will be reinstalled on next restart.
After that plug USB pen drive to usb port - go to start->control panel->system->hardware->device manager. Click Universal Serial Bus controllers then click on Action tab (the one at the top of Device manager window and select scan for hardware changes.
If that will not solve the issue try different USB port.
Make sure you have latest service pack installed so Windows would install proper drivers for the device.
Let me know if this is not solved
May 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
Delete key, dash key and six key does not work on Sony Vaio laptop
Usually this is due to a hardware problem with the keyboard. 98% of the time by replacing the keyboard you'll fix the problem.
You could also try reinserting the data cable from the keyboard to the motherboard.
It can sometimes get a tiny tiny bit loose and cause problems like this.
Be VERY careful when you remove the plastic tab that holds the keyboard data cable in place. They are EXTREMELY easy to damage.
I know I've messed up plenty myself
:-P
Best of luck!
Feb 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
I have a problem with keyboard volume control
These instructions are for Windows XP:
  • The volume button, brightness key, and disc eject button on some computers will not work if the HotKey Utility application is not running.
  • The Magnify button and the Fn keys will not function properly before the operating system has finished starting.
  • The setting may not be saved if the ESC key is used to close the Fn display. Press the ENTER key or allow the Fn display to close automatically to save the setting.
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type MSCONFIG .
  3. Press the ENTER key.
  4. In the System Configuration Utility window, click the Startup tab.
  5. On the Startup tab, under Startup Item , ensure that there is a check in the HKserv checkbox. NOTE: If HKserv is missing, reinstall the HotKey Utility application and the Sony Utilities Library.
  6. Click the OK button.
  7. In the System Configuration box, click the restart button.
Feb 07, 2009 | Sony VAIO VGN-FJ270/B Notebook
Key came off
Try www.laptoprepair101.com
Jan 03, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
