Question about Sylvania LC320SL8 Television
SYLVANIA LC320SL8 - NO PICTURE
WHEN YOU PRESS THE POWER BUTTON, PICTURE BRIEFLY FLASHES "DIGITAL TELEVISION" THEN SHUTS ITSELF OFF.
POWER LIGHT GOES OF AND TV RETURNS TO STANDBY MODE
  • Anonymous Jan 05, 2009
    i have the same problem, like many others.
    I searched the web and cannot find any solutions
2 Suggested Answers
SOURCE: standby mode
It happened to me.. a FAx to Enrique. in California.
Posted on Jul 12, 2007
dsacco86
  • 1077 Answers
SOURCE: Sylvania Lcd 32 in.
Is it under warranty by chance?
What is happening is when you turn on the TV, it's trying to power up the screen at that moment. If it can't power up the screen, it will turn off automatically. This is what they call, "Protection Mode".
All the TVs made by Funai (Emerson and Sylvania) are having the same problem. The Inverter Transformers needed to power up the screen are somewhat low quality and burn out easily. I'm sure of of them burned out.
Your TV, I believe, takes 6 of those things to power the screen. And they are all on one circuit board.
If the TV is not under warranty, then let me know what the board number is on that circuit board. The board inside the TV should have maybe 6 connectors that hook up the screen. I may be able to track down a replacement board for you.
Posted on Apr 25, 2009
TV turns off and goes to standoff
Top 129 Complaints and Reviews about Sylvania TV
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.7 - ‎93 votes
I purchased a Sylvania 32" TV from Best Buy about 6 years ago and based on all ...While watching a television program, the television would turn off and come ...
Top 129 Complaints and Reviews about Sylvania TV ' Page 2
I have to press the power button on 3-7 times before the TV actually turns on. ... My almost new Sylvania TV started cutting off and coming back on after about 10 ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn .... Common TV Repair for Emerson, Sylvania, Philips, Magnavox - no ...
My Sylvania is turning on and then turning itself off within
Jan 10, 2016 | Sylvania LC320SLX 32 in. LCD TV
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
42" sylvania 6842thg plasma displays digital television and then shuts off after about 1 minute.
Evening It is not energy saving that is bothering you,is it? Try SET-UP and see if you can change it there. Good luck Kolbrun
Aug 24, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
Power on lights ,blinks, goes out
How many times do the power LED blinks at a time, before the set goes Off?
Jul 22, 2012 | Sylvania LC320SL8 Television
I have a sylvania 32 inch tv everytime i turn it on the green light blink then goes back to red
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.if otherwise, power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem...
May 29, 2011 | Sylvania LC320SL8 Television
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
When i turn my tv on the screen flashes digital then turns off
Basically, the TV is trying to power up the screen. If it fail to do so, the TV will automatically turn itself off to protect other part from being damaged inside. The problem is going to be the Backlight Inverter Board. It's the circuit board that supplies power to the screen. You can usually find a replacement board at a good price at Shopjimmy.com
Aug 20, 2009 | Sylvania LC370SL8 37 in. LCD Television
Sylvania 32 in lcd
IF YOU HAD THE TV ON AND PS3 AND PLUGED IN A HDMI CABLE THIS MAY HAVE CAUSED A SHORT AS HDMI CABLES CARRY POWER. YOU WILL HAVE TO GET A REPAIR MAN TO FIX THIS.
Jun 26, 2008 | Sylvania LC370SL8 37 in. LCD Television
Sylvania LC320SL8 Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
