Question about GE WHRE5260E Top Load Washer
What is the load capacity for the GE WPSE4200AOWW Washing Machine?
    Sergeant:
  • 311 Answers
Not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
Posted on Jan 01, 2009
Ge washer won't let water spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
How do I open the washer up to check and see why it is leaking water WPSE4200AOWW
You can remove the front panel by pushing in the two retaining clips in the seam where the panel meets the washers top using a putty knife, while you pull the top of the front panel forward.
Jun 20, 2010 | GE Profile Prodigy WPSE4200A
Washing machine does not cut off at the preset capacity.
check to make sure your drain hose is positioned higher than the highest water level in the machine, loop the drain hose up higher than the drain and secure it to keep the water from siphoning out.
May 29, 2010 | GE Profile WPRE6100G Top Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Best washers ?
the larger capacity maytag with the larger gears in the transmission can break. the standard transmission on some of the ge are bad, the coupling breaks in the kenmore and whirlpool if you overload.
I still like maytag the best and I have been in the appliance business 19+ years
Dec 14, 2008 | GE WBSR3140DW Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
483 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
