Question about SAMTRON 55V 15" CRT Monitor
Problem with samtron 56v 15" monitor
Iam using samtron 56v colour monitor and i'm using windows xp. i have got 2 problems. first problem : my screen size is reduced whem iam adjusting monitor settings manually (by using buttons on monitor).i tried so much but my screen size is not increased even though horizontal size is 100 or full. second problem : manual setting screen (screen which comes when we press menu button on monitor) is displaying continuosly even though i press exit button.it closes for a second and displays again without any interaction. please give me some solution as im facing the problem for the last 2 days.
  • sirahari Jan 14, 2008
    All of a sudden, my monitor (Samsung-Samtron 56V) features--brightness, contrast, etc.,-- are appearing on the screen by themselves. They keep flickering on and off, lock and unlock ControlLock and do not go away even with repeated pressing of the exit button on the monitor. Keeping the exit button depressed even changes the display width, and contrast.
    So I have reinstalled the Operating system (XP). But to no avail. I had a host of viruses before reinstalling the OS. The viruses are gone. Now I have AVG free anti virus running. I have also tried downloading 3-4 antivirus' from the web and run them one after the other. But this monitor problem persists.
    Need urgent help.
    Srihari
  • Anonymous Mar 13, 2014
    I have black bars on all 4 sides of my new monitor and cannot adjust using the onscree acer menu
    Problem Solver:
  • 3 Answers
For first problm I suggest that plz. soldering (very well ) EHT secsion other wise change width control transistor.
for 2nd problem chq. control buttens if ok then chang 5 volt regulator IC (7805) . infront of micro controler ic . probelem will be solved.
Posted on Jan 16, 2008
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE:
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
NO DISPLAY
try to check all components (smps section )
Apr 08, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor problem
i think the problem is in your monitor and it is not manuall. any part of your monitor might have been damaged ,so get it checked by an hardware expert
Feb 24, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Screen settings problem
OSD = On Screen Display. Once loaded it is normal for the OSD to stay on your screen untill it times out or you Exit it.
Nov 24, 2007 | Samtron MONO TTL 13 Monitor
Monitor
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
325 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
