Question about Onkyo TX-DS939 Receiver
Problem with onkyo tx 919 unit
I posted wrong here sorry,,, i have a tx 919 thx unit it keeps getting a protect error on it i have had it fixed 3 times is the circuits running hot for some reason or would you be able to tell me what the problem possibly is and, also is there that much of a difference between the 919 and the 939 tx onkyo units? thanks again
    Genius:
  • 1,175 Answers
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Posted on Jan 01, 2009
No output on my Onkyo TX-SV919, please let me know whats wrong with this receiver
Hello, I am sorry about your issue. It would be difficult to determine where the problem lies. I suggest having the unit serviced or traded in. Thank you, Onkyo USA
Apr 25, 2017 | Onkyo Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Looking for a manual for the DVL-919. Running it though a Onkyo TX-NR807 AV receiver and it keeps defaulting to monochrome.
okay check electromaniacs.com for a free copy.or partstore.com to buy one which ever you choose.good luck
Feb 28, 2010 | Pioneer DVL-919 DVD Player
Onkyo TX-SV414Pro. No audio. Displays "Protect"
something is wrong either in one of your speaker connections or in the unit itself unplug for awhile to reset.try it again.make sure all connections are correct and nothing is touching.if that does not work it will be the unit itself
Jun 11, 2009 | Onkyo TX-SR803 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Channels missing on Onkyo TX-SV646
These units are quality units. The fix is not the easiest. We need to determine whether the problem is the output amp sections or the processing side. Worse case, the cost would be around $50-$75 for parts plus the local labor rate. Given your description, it will be difficult to diagnose remotely. One alternative is to get a detailed repair estimate ($50 or so) and post the results here. We can walk you through the actual repair.
Dan
Sep 12, 2008 | Onkyo TX-SV646 Receiver
Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Jul 28, 2008 | Onkyo TX-NR905 Receiver
Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Nov 04, 2007 | Onkyo TX-DS939 Receiver
ONKYO TX-SV717PRO Amplifiier
disconnect power and try after 20min without speakers.
Aug 19, 2007 | Onkyo M-282 2-Channel Amplifier
Amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
Apr 29, 2007 | Onkyo TX-SV373 Receiver
Onkyo TX-DS939 Receiver Logo
562 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
