Question about JVC KD-G210 CD Player
Wiring Harness Two of my wires have been pulled out the harness for my jvc kd-g210 stereo. One of the wires is the yellow battery wire and the other is the purple positive right rear speaker wire. Can i replace the wires with another that have similar or the same characteristics. If so, at which points in the harness are they positioned?
I had some two conductor wire, which is used generally for alarms or for low voltage items, umm what i would recommend is you can use some of the two con for the Purple positive on your harness, but get something a bit thicker in gauge for the Yellow battery, use something more that would accutaly hold better power that you can use in terms of powering items, you should be able to get away with using something like that sorry if this isnt too much help, best bet is using alternative wires, otherwise try a Radio Shack they might have a Radio Harness or even bestbuy
Posted on Oct 14, 2007
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Is there a universal harness that i can purchase
Hello james_sweet,
You can purchase a wiring harness here for your JVC prewired with a plug for most vehicles.
Hope this helps.
Jul 11, 2009 | JVC KD-G210 CD Player
I need help..
make sure you have the power wires correct. yellow should be hot all the time and red is for when thr ignition is on... you may have them backwards, or the ignition line isn't getting power...double check your power source and the fuses.
Oct 17, 2008 | JVC KD-G210 CD Player
Wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Jul 20, 2008 | JVC KD-G320 CD Player
JVC KD-G210 CD Player Logo
125 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
