Question about Polaroid FLM-4201 42 in. LCD Television
I can hear audio on all stations except one?
Polaroid LCD tv is brand new. All stations are working and audio is can be heard on all except channel 5. What could cause this?
  • Anonymous Mar 30, 2009
    My TV has sound except the two ABC channels. Why would there be no sound for one network?
  • 37 Answers
Check on your remote for a button labeled MTS/SAP or something similar -- try pressing it (possibly more than once). Sometimes this can cause audio to be heard on some channels but not on others...
Posted on Jan 01, 2009
Ive retuned, re-set, unpluggest and plugged back in and i recieve no channeks still, been like this for months
What is your TV source? The Polaroid LCD-2000 only has a NTSC (analog) tuner. Most OTA stations switched to ATSC signals a few years ago and a converter box is required to watch the TV. (A few low power TV stations still broadcast in NTSC but you need to be fairly close to the transmitter to receive the channel.) If you have cable, check if they have migrated to digital cable (QAM for unencrypted channels). If that is the case, you'll need a cable box.
With a digital-to-analog OTA converter box, you can still lose station reception due to the signal strength cliff. Depending on your area, you may need an external antenna or to check the direction of the antenna. I know I have to rotate the outdoor antenna every so often. It shifts in high wind. Even if the antenna only moves 5 degrees, we will lose the signal for half of the stations.
I hope this helps.
Aug 10, 2015 | Polaroid LCD 2000 LCD2000 TV flat screen...
Tv has sound on all channels but one. Had sound but 30 min later no sound. When watching two tv's on same channel the one with no sound was lagging behind other tv not in sync as all other tv's in house...
Check to see if your audio source is set to SAP. This stands for secondary audio program. For example, some stations broadcast english and spanish. Some stations broadcast english and nothing. If you are on a channel that broadcasts english and nothing, and you are SAP setting, you will hear nothing.
Jul 03, 2010 | Sony KDF-E42A10 42 in. LCD Television
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
May 01, 2010 | Sharp Televison & Video
My 26" TDX-02610B LCD Polaroid Flat Screen sometimes goes haywire. On these occasions, remote will not work, except sporadically, and TV responds in fits and surges, scrolling uncontrollably up or down the...
Take out the piggy back signal should solved this problems,not than ur Tuner Signal board have some kind of intermitten short in the board.Must replaced the bard.
Mar 13, 2010 | Polaroid TDX-02610B LCD TV
Polaroid 23" HD LCD TV
You need to select auto channel find from your tv menu
Aug 31, 2008 | Polaroid Televison & Video
Analog or Digital?
This tv is analog, EDTV is only enhanced definition tv ,480p resolution, not the HDTV 1080i or 1080p resolution, the mts/sap tuner has to do with the audio decoder. For example: SAP would allow you to view a station broadcast in english to be heard in spanish. MTS is surround sound broadcast. Thanks
Apr 02, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Polaroid LCD 32" TV
The user manual was no help. I called Polaroid and they help me solve the problem. Very helpful and spoke English which is unusual for customer service anymore.
Mar 29, 2008 | Polaroid FLM-323B Television
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Hi help me pls
the code is 11498 for the polaroid tv's but i got mine to work by making the remote search by brand under tv. when the tv changes channels just exit the screen on the remote
Nov 11, 2007 | Philips PM-8FS LCD Touchscreen Remote...
Polaroid FLM-4201 42 in. LCD Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
