Question about KitchenAid KAWS850L Top Load Washer
How do you assemble the back on the top load kitchen aid washer? I can't get the cover to sit on the frame.
    Sergeant:
  • 311 Answers
Its not supose to come off the way you took it off.slide the top over the back metal.screw the hinges back in.and put the screws back in inthe frount or pop it in,depending what one you have.its just most important that its not vibrating and making noise.God bless,tom
Posted on Jan 01, 2009
Washer fill with water model # LA4800XTW0 then just sits there no agiate no spin water will then drain once switch is manually advanced. Lid switch problem? OR direct motor coupler?
Hello, welcome to FixYa.
Based on your post, if you mean manually advancing the timer it will drain, it's a coupler. If you mean manually activating the lid switch, it is the lid switch or lid switch strike.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...based on the model provided, it cover's yours)
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Washing Machines
Clean under agitator on a Kitchen Aid top loading washing machine.
To remove the agitator to gently remove the cap from the top - it will have a rubber o-ring seal. Beneath it there should be a nut and washer assembly remove that. Then there should be a stack of agitator parts - clutch, upper agitator, lower agitator. Set them aside in the order you remove them. then back in the opposite manner.
Hope this helps.
Joseph
Apr 16, 2011 | Washing Machines
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
Cabinet and back of washer are not fitting after replacing lid switch
The bottom front of the cabinet fits under the front of the frame, and the sides sit on top the frame. There is a notch towards the rear of the sides (on the bottom) for alignment to the frame.If they are aligned, the back will match right up.
Jan 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
Top loading kitchen aid washer that shakes down the house
probably wouldnt look under hte agitator for problem. although the trick is to hold t he agitator while loosening hte bolt, it will then lifts right off after bolt removed., i would remove hte cover and perhaps look for a broken spring , bleach sometimes falls through rusting out metal brackets
Dec 05, 2008 | KitchenAid KAWS850L Top Load Washer
I have a Kitchen Aid clothes washer and the tub that you put clothes in won't stay centered. When it spins during the spin cycle, it gets out of balance and thump, thump, thumps............me and the...
there are 3 springs that hold it to the frame,remove the 2 screws from the washer head,one on each side,now pull up on the head and lift the front out and up,you will see 2 spring clips pop them out with a flat screw driver,open the lid and pull the washer case toward you,sit it aside and look at the other springs they will tell you where the other one goes,also the tub sits on a triangle bracket make sure that is in place to,under the tub,let me know-mike
Sep 26, 2008 | Washing Machines
My kitchen aid washer leaks from bottom
top load? lean back remove bottom cover if any ckd pump most likely suspect
Jul 08, 2008 | Whirlpool Washing Machines
Kitchen Aid KAWS700600 washing Machine
this machine is accessed from the front. take two control panel screws off flip up panel. unclip lid switch connection. take screwdriver and insert vertically in front of gold clips pry by pushing handle to rear of machine. rotate entire housing toward you . to reassemble ensure front lip of cabinet goes UNDER forward edge of frame
Oct 19, 2007 | KitchenAid KAWS750L Top Load Washer
KitchenAid KAWS850L Top Load Washer Logo
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
