Question about Philips 60PP9352 60" Rear Projection Television
Philips 60PP935217- White horizontal lines on entire screen
Can barely see a picture in the background. Screen is covered with horizontal white lines. tried 75Ohm connector, composite, and component connections with same results. Any help is appreciated.
  • jbernetich Jan 01, 2009
    Additional information: the menu and on-screen status ( channel, input indicator and all menu items including the convergence tool) are perfectly clear and are displayed on top of the white horizontal lines.
    more info from jbernetich. I downloaded the service manual for DPTV310. Got into the SDM and there were no error codes. Checked to make sure all SDM options were set per the manual correctly. Got into SAM and all normal except for on the GDE Mode. Appears to be an error as follows:
    SWID: GDE 1.08
    ERR: KMNPQ
    cant' find a table to break down this error in the Service Manual. Any help?
5 Suggested Answers
  • 308 Answers
SOURCE: green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Posted on Jan 14, 2007
Shuttle83
  • 1139 Answers
SOURCE: Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
Posted on Sep 24, 2007
premtech
  • 934 Answers
SOURCE: blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Posted on Nov 14, 2007
Benimur
  • 6966 Answers
SOURCE: hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 15, 2008
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Philips 60PP935217 60 in. Rear
I would check the regulator transistors and then the horizontal output tarnsistor.
Apr 09, 2008 | Philips 60PP9352 60" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Screen problems
have you checked the cable between the base and monitor for a fault ie broken cable, lose conector as it sounds like a signal problem, common fault for alot of laptops with the screen being open and closed allot all my best ric
Oct 12, 2007 | Toshiba Satellite 1905-S277 Notebook
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
