Question about Sanyo SR-172 Compact Refrigerator
SR-172W not cooling
I have many Sanyo SR-172W in my small hotel. One of them is no longer cooling. How do I tell if the refrigerant is gone? How can I make it work?
  • Anonymous Mar 19, 2014
    Where can i find a temperature sensor to fix my wine cellar that never stops cooling?
    Novelist:
  • 114 Answers
MOST CASES ... THEY ARE NOT LOW ON 134A . TO TELL ... YOU NEED ONLY START THE COMPRESSOR AND HOLD YOUR HAND ON THE SMALLEST COPPER-LINE ... IF IT GETS REAL HOT 110-130 DEGRESS YOU HAVE A CHARGE. IF YOU MOVED THIS FRIG. AT ALL LATELY MAKE SURE YOU LET IT STAND UPRIGHT UNPLUGGED !!! FOR EIGHT HOURS. YOU CAN ALSO SPEED THINGS UP BY: HEATING WITH A BLOWDRIER BOTH THE COLD PLATE INSIDE AND THE BOTTOM OF THE COMPRESSOR ... THIS BOILS ANY REFRIGERANT OUT OF THE OIL AND LETS THE OIL RETURN TO THE COMPRESSORS OIL RESEVOIR THAT IS AT THE BOTTOM OF THE COMPRESSOR. THESE SMALL FRIGS ARE GREAT ... BUT FRAGILE TO MOVE AND DEFROST. OIL CAN GET TRAPED IN THE COLD PLATE AND NEDDS TO BE HEATED OUT OF THERE AND SOME UNFORTUNATELY USE METAL OBJECTS TO DE-ICE. A LOW CHARGE WILL NOT FROST THE COLD PLATE (EVAPORATOR)EVENLY AS IT SHOULD. LOW CHARGES (AFTER YOU HAVE DONE THE ABOVE) ... WILL ICE UP IN JUST A SMALL SECTION WERE THE PIPES AND CAP-TUBE GO INTO THE COLD PLATE. THESE DONT LEAK UNLESS SOMEONE TOOK A ICE-PICK OR EQUALLY AS DEVESTATING TOOL TO DEFROPST IT. ONLY WAY TO DEFROST QUICK IS WITH HAIR DRIER ...DO NOT PROP-IT UP IN THERE AND WALK AWAY .. YOU CAN MELT OR WARP INSIDE PLASTIC HOUSING !!!!! THEY ALL NEED MANUAL DEFROSTING THE MINUTE ICE STARTS ACCUMILATING. OR BUY A APPLIANCE GRADE HIGH AMP (10 AMP) PLUG IN TIMMER AND SET TO GO OFF AT 3AM AND COME ON AT 4PM ... ONLY 1 HR. IF THERE IS A VISABLE HOLE IN THE EVAPORATOR COLD PLATE ... IT IS ALUMINUM AND FORGET ABOUT EXOPY KITS TO REPAIR THEY ONLY LAST A YEAR IF THAT. IF YOU CALL TO HAVE IT REPAIRED RIGHT WITH SOLDER ... USUALLY A REPAIR LIKE THAT WILL NOT BE WARRANTIED AND PROBUBLY COST MORE THAN TO BUY A NEW ONE. GOOD LUCK.
Posted on May 07, 2007
The round metal ball looking thing in back of mini sanyo sr-172w sounds like there something loose is it soppose to sound like that?
The round metal ball thing as you call it is the compressor. They generally run pretty quietly but do rattle a bit when they stop. The casing will also feel fairly hot to the touch. However, if the compressor is making a constant rattling noise I think that maybe you should get it looked at. Since this is the main thing that runs a refrigerator I would imagine that replacing it might be fairly expensive. You'll need to balance repair against new depending on how old the 'fridge is. Sorry to be a bit of a gloom merchant but I have to tell it as I see it.
Jun 29, 2015 | Sanyo Refrigerators
I recently moved and my Sanyo Sr-3720 has stopped cooling all together. Neither, the ice compartment nor the fridge portion cools the air at all. I can hear the motor working, but nothing seems to happen....
A refrigerator should be allowed to stand upright for at least 24 hours before operating, after moving. There might be liquid refrigerant (now) in the compressor. These kind of compressors cannot pump liquids, only vapor. I suggest that you warm the compressor with a blow dryer to vaporize any liquid refrigerant that may have migrated to the compressor. Also check for any leak (oil) that may have developed by handling it.
Aug 26, 2013 | Sanyo SR-3720M Counter-High Refrigerator...
My Sanyo SR-4911m refrigerator does not cool. Compressor seems to turn on when termostat is turn from off position to on position. However, compressor gets really hot and gurgles, but does not cool the...
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Jul 04, 2011 | Sanyo SR-4911M Compact Refrigerator
After someone cleaned my sanyo 3370 refrigerator it's on nut not getting cold.I hear a noise but not sure what it is.
it sounds like ice has built up on the evaporator. This is will prevent air flow that will cool the fridge, it will also touch the fan and make a noise.
You may find that the defrost heater has been dislodged from it's normal position and can no longer melt the ice on defrost.
You should get a technician to fix this problem
Mar 24, 2011 | Sanyo SR-3770S Compact Refrigerator
Sanyo SR-4800W freezer is ok and cold stoeage is warm. Need to fix the problem.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Sanyo SR-4800 Top Freezer Refrigerator
What is the wattage requirement for the Sanyo SR 172W?
Although the information is not published by Sanyo I was able to find out that the fridge uses about 90 watts.
Jan 06, 2011 | Sanyo SR-172 Compact Refrigerator
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Not cooling....
Sounds like you checked for the proper items, fans to move cold air, etc. and if stuck in defrost mode. If the compressor is running you would have to be cooling unless... the refrigerant has leaked out. And that is basically a bad thing. If in defrost cycle the compressor would stop while defrosting soooo it's looking like the refrigerant is gone. Can you take the back interior panel off to see if the coils have a full frost pattern?
Jan 04, 2007 | Sanyo SR-4911M Compact Refrigerator
Sanyo SR-172 Compact Refrigerator Logo
306 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
