Question about Kenwood KAC-9102D Car Audio Amplifier
Well i got the kenwood 1800 wat amw and ive had it for like 4 months now and today it was hot out side and i had the volume very high and i guess the amp got hot and turned off then it came back but it was not sounding ass hard as before but i also think its because of the speakers cause the speakers cant handle the power and there also kenwood but they could only handle 1000 wats so can some one help me plz
    Problem Solver:
  • 13 Answers
Move your amp to a place in the car where it gets more air than it does at the moment so that it can be kept cooler for longer...
Posted on Aug 15, 2007
SOURCE:
How do i wire a kenwood amp to two 8in woofers
at low volume any speaker works impedance mismatches wont matter(thats the 4 or 8 ohm resistance speakers have) , but at huge volume you need to consider a crossover circuit in the wired line
or a booster amp that does it for you.
when you have a huge volume level, the coils will feed back (counter emf ) some of that power back into the transistors driving it.
some transistors can die if mismatched badly at power up with high volume level. or disconnect while runnning a load.
depending on the amps design..
hot plugging anything is taking a risk no matter.
see page 8 of your manual below
http://inform3.kenwoodusa.com/manuals/krx793.pdf
Jul 09, 2014 | Kenwood KAC-8405 Performance Series 4/3/2...
How do i adjust the time on my casio amw 704
Record your module number from the watch back, then go to this link:
http://world.casio.com/wat/download/en/manual/
I hope this helps you. Thanks.
Aug 30, 2010 | Casio Hunting Gear Amw 704D 7AV Watch for...
I am looking for a user manual for casio AMW-705 - 4735
Here you go
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4735&submit.x=28&submit.y=8
If you would like to find manual for any other model you need this link
Apr 25, 2010 | Casio AMW705B 1AV Hunting watch
Kenwood DDX7015 password reset please help
yo u need a reciet of purches and u can send it in. do wat i did go to a sound shop ask one of the people there to make u one and slip him a twenty beleave me its worth it i got the same screen as u and its bad ***. try it
Apr 06, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Jan 08, 2009 | Kenwood KR-V5580
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
Nov 05, 2008 | Casio AMW700B 1AV Pathfinder Watch
Need to know
I would recommend running a four channel amplifier using component speakers up front and co-axial speakers in the rear. You can add more speakers up front, but it depends on what you're trying to accomplish in your car. Do you want it louder? Do you want it clearer? Any system will benefit from an amplifier. More power to your speakers will give you better sound because you'll have more accurate control over the speaker cone. This extra power will result in better clarity, not only at high volume, but low volume too.
Sep 06, 2008 | Kenwood KDC-3024 CD Player
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp keeps overheating
Try to turn down the volume??? LOL No really most likly the voice coil is overheating on the speaker, or the unit is over heating. Try to add a fan on top of the unit as I found this on high powered units, that they are being push hard and getting hot. Is the amp really hot when it does this? If it is then its a normal thing as not enough venilation. if its not hot then theres a problem in the amp and should be bench checked by a pro with load resistors and a tone generatoe as well as a scope to check if theres a clipping problem in the output stage.
Sep 02, 2006 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
46 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
