Question about Hotpoint VVSR1070D Top Load Washer
Washing Machine will not agitate
All cycles with the exception of the agitator operate properly, but the agitator will not work. Where is the agitator solenoid located? Do you have to remove the tub in order to access the agitator? Thankyou
  • 4 more comments
  • meetzu2 Dec 19, 2007
    washing machine will not agitate or spin without assistance or if too much is in the machine. need help with removing the agitater.
  • Anonymous Feb 08, 2008
    Washer try to agitate and then motor get hot and stop and then again it tries to do the same thing every minute or so. At the bottom of the washer I see lot of greese/thick oily substance. Is this coming from transmission and whether it is bad transmission that is why the washer does not agitate. Rest everything works fine.
  • stelcaro Feb 10, 2008
    none
  • jeffandi Aug 05, 2008
    Washer spins but won't agitate. I've been told it could be a solenoid. How do I check it?
  • Anonymous Sep 10, 2008
    agitator will move but very slowly
  • lil cher Feb 09, 2009
    Hotpoint washer barely agitates during wash cycle only,
    the clothes basically just soak? What causes this? How
    do I fix this?
How to take off agitator
Posted on Feb 10, 2008
I have a crosley washing machine it works perfect except the other day it mmade a loud noise and every since then the agitator works but it jiggles and stit makes a loud noise there was some grease on the floor. But it still agitates .
Posted on Sep 18, 2012
  • 87 Answers
Pull agitator out, you will find an agitator coupler stripped out.
Posted on Jun 09, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
How to remove agitator in Beaumark Super Capacity washing machine?
https://m.wikihow.com/Remove-a-GE-Washer-Agitator
Jan 12, 2018 | Washing Machines
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
Neptune washer will not go past the first wash cycle
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't spin
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken.
Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Last the huming may be the motor is sized! Done, finished!
This is not a do it your selfer job
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
-no agitation
Hello
Welcome to Fixya
My name is Huum,
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
Hotpoint VVSR1070D Top Load Washer Logo
2,559 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
