Question about Carlton HES-40 4,500-BTU ELECTRIC STOVE Heater
My electric stove suddenly started chirping, then squealing. It seems to come from behind the dials.
I have a 1996 Isuzu trooper and when i start it it runs fine then after awile the chirping /squeal starts. and the voltage meter was under 12 violts then a fan would kick on and the volts would go up to 14...
Could be the alternator .
A Battery store could test your car's battery and alternator to determine if the alternator is working correctly and that the cars battery is ok as well.
Apr 21, 2017 | 1996 Isuzu Trooper
Why does my viper alarm suddenly start chirping?
Mine does that too (chirps 8 times), every 4 to 8 hours or so (seems to be random but persistent). The alarm was installed November 2014 and I just started noticing it in May 2015, possibly because I am now within earshot of where my car is parked?
Apr 28, 2012 | Viper Security and Remote Start System...
Windstar 2001 had it since new. over 120,000 miles suddenly started stalling cuople months ago had alternator replaced, bearings anything on the serpentine belt incl oil and water pump checked or replaced....
The problem with your van is the CAM Sensor, I believe the noise you are hearing is kind of a chirping sound. I just had mine fixed (12/19/09) it was about $150 for parts and labor from a local Mech. not a dealer.
Dec 17, 2009 | 2001 Ford Windstar
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Whirpool Imperial Series Stove turns off while I'm trying to bake
there is a control board just behind the clock. on that board is an omron g2rl-1a-e-cf, 9vdc, 16/250vac type relay. i replaced that relay with an equivalent wired in one and that fixed the problem.
Jun 19, 2009 | Whirlpool GR460 Electric Kitchen Range
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Electrical problem w/ magic chef electric range CER3540AAA
hi thanks for the question i would check to see if theres 240 volts at the stove if only 110 volts at stove you will not get any heat but lights will work check that replace fuses in main panel for the stove thanks the appliance doc
Sep 27, 2008 | Kitchen Ranges
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
My oven doesn't light
you should check your fuses located in the top of your stove
Feb 16, 2008 | GE JGBP24 Gas Kitchen Range
Heating & Cooling Logo
27 people viewed this question
Top Carlton Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Carlton Heating and Cooling Expert? Answer questions, earn points and help others
