Question about Fagor Ovens
Top oven door glass has smashed
I need to remove the top oven door to put the new glass in but cannot see how to detach the hinges from the main carcass. can you help?
  • Fagor Master
  • 3,463 Answers
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Posted on Jan 01, 2009
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
How to clean just oven glass under my cookiop
usuallu the oven door has to be separated to clean it the way many like to see them . caution tho doors are heavy and if dropped the glass can break tip open to where it will stay open and lift off hinges . around outer edge will be screws that need removed . lift the top half off and wash the glass . when done put back together and refit to the hinges .Luck be with you
Jun 19, 2016 | Ovens
How do I remove and replace the main oven door inner glass
partially open door and lift off the hinges . lay on a flat surface and remove the screws around the outer edge . separate the halves of the door carefully . take old glass out ,put in new and put it back together .
Jan 28, 2016 | Ovens
H4080bm Miele microwave handle fell off
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
Aug 23, 2010 | Miele H4080BMSS Oven
Cleaning glass in oven door
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. The glass slides out from the tabs and you can give it a good cleaning at this point. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Jul 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
249 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
