Doesnt want to play certain osngs
Help, my f400 mp man is freaking out. Everytime i click on a song it would say no files found, but th eformats are mp3. is there any way to reset the system?
    Genius:
  • 1,011 Answers
Dear,
the place u saved the songs, the song(s) has/have been deleted but remained in list. i think this is the case.
u save songs from other source and then listen it from list by adding to list.
regards,
Posted on Jan 01, 2009
How do i get the music off of my Coby mp-c582 1 gb mp3 player..tried to push reset but nothing happens
Try this method:
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Dec 16, 2009 | Coby MP-C582 MP3 Player
Cannot delete files
Try this solution to your proplem
Dec 12, 2009 | Coby MP-610 MP3 Player
You need to use MP3 or WMA files.
Sep 07, 2009 | Coby MP-610 MP3 Player
Songs wont play :-(
You have to make sure your songs are MP3 or Unprotected Windows Media Audio files. You can check this by right clicking the song, go to Properties, it will tell you the type of file, make sure its says MP3 or the song is not compatible with the unit. Below is a link on how to add songs through windows media player:
http://http.vitalstreamcdn.com/cobyelectronics_vitalstream_com/setupguide/MPC7095_SG.pdf
Aug 22, 2008 | Coby MP-C7085 MP3 Player
Coby mp-833
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
Aug 22, 2008 | Coby MP-C883 MP3 Player
My Zen Freaking Froze Up!!!
Reset button to left - use a paperclip. If its a 4gB it might be faulty.
Apr 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Coby mp3 player problem
Write the songs to a CD (or a CDRW) first, then re-rip them to Windows Media Player/iTunes/whatever as mp3s, or unprotected WMAs.
Honestly it's easier to burn and re-rip than remove the copy protection. When you burn it to a CD, the DRM goes away, and you'll have a new file that actually plays on your player.
Dec 23, 2007 | Coby MP-C883 MP3 Player
ILO keeps disconnecting
I have the exact same player. To begin syncing DOES NOT WORK with this player, don't waste your time. When it says that you need media player 10 it really means just that. I have m.p. 11 and it did the same thing. If you don't have M.P. 10 available the best way to load music is through drag and drop or use the "send to" command in the right click menu. Also the cd is only for computers that are working on windows 98 or lower. You also will have to go in and delete each song you did sync on the player. They will behave as corrupted files and keep it from playing properly if you don't.
Oct 08, 2007 | iLO (2 GB) MP3 Player
Sony walk man mp3
try these methods
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Mar 23, 2007 | Sony DNF420PS Walkman Personal MP3/CD...
 Grubhead
Grubhead
