Question about Dishwashers
Will not drain out the water ,i have used drian cleaners for 2 days ,no luck still will not drain ,any suggestions . thanks don
  • 311 Answers
Don no more drain cleaner! im not sure how your going to do this with that stuff in their.most drain problems are at the air gap on the sink[take apart clean]then disposer,and work your way back to washer from there.that said i assume your washer is going thru the motions [noise tring to drain]God bless,tom
Posted on Jan 01, 2009
When I wash whites they come out grey. I put them in seperate from colours. I have cleaned the filter and the dispenser draw but it still happens. I have also used a washing machine cleaner and have run...
Is it possible that the water is not hot enough? Can you judge easily?
A suggestion/action which could do 2 things at once- clean the heating element and (maybe) kick the 'NTC' (water thermostat) into correct operation. I know you have used a cleaner and run maintainance washes but I would certainly try this.
I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour the contents of 2 kettles of very hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 02, 2011 | Washing Machines
My side by side for some reason has water coming out from under it..i check the water feed line and its good!I then checked the drain plug in the frezzer and noticed the whole bottom of the frezzer had...
What is a "drain plug"??? Never seen one on a fridge ;)
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
First Choice Appliance
Dec 21, 2009 | GE GSS20IEP Side by Side Refrigerator
I have water that hasn't drained out of the bottom of dishwasher and when trying to run it, the panel lights come on, but the machine does not turn on.
It sounds to me as though the water drain line is connected to the house too low. If it is installed using the sink drain line be sure it tees into the drian as high up as possible. As far as the machine not turning on, it could be the water level interlock that sences water in the machine and will not allow it to start.
Hope that helps. Good luck
Dec 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
2002 beetle. Water on floor/passenger side - Vapor barrier faile
open doors and look for drain holes try sliding a wire into holes does it go in easily? if yes they check door seals for torn of loose seal, is there a sunroof/moonroof does this leak? get in car and have someone hose for awhile and look for leaks with a flash light? if door drian holes are blocked remove panel and clean inside. have you been using a/c? if yes is the a/c drain line blocked and condensation is leaking into cabin, also the front windshield has a grate at bottom remove grate and check channel for blocked drains or leaking seal. good luck on this one of these should be your problem.
Oct 30, 2009 | 2000 Volkswagen Beetle
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
I have a whirlpool refrigerator where water pools under the veggie crispers. It looks like it is coming from the freezer. The unit does not have an ice maker and I suspect a drain line is clogged. Any...
Freezer on top? If so remove rear panel from freezer inside and check drain under evaporator. If clogged, use hot water and turkey baster to squirt water and thaw out drain. DO NOT use sharp instrument to pry ice out. You can use a blow dryer to help thaw as well. Turkey baster helps to jet hot water in drian.
Jun 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Pegasus Push Button Drain leaks when you push the button
Mar 09, 2009 | Plumbing
Maytag model no: dwu8530aax installation
under counter dishwasher installation look under sink is plumbing set up for dishwasher? drain and water supply? if no you need to do some plumbing. if yes you need to supply power- water- drian it just slides under counter and is screwed in with 2 screws in 2 brackets on front top of dishwasher. thank you for useing fixya please rate me if you need more info contact me thank you again
Feb 20, 2009 | Dishwashers
Water in rear quarter panel
This is a known issue whne the car is running down the road a vent flap will open up and road spray will get into the trunk. There is also issues with the convertable model. that isknown by ford.
Dec 13, 2008 | 2006 Ford Mustang
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
