Question about Philips 46PP9302 46" Rear Projection Television
Phillips 46"rear projection with moving (Red & Blue )bowed image
I have a 46-inch Philips Rear projection TV. Recently, its image has become distorted. Red and Blue have a moving bowed image.
Any suggestions of what needs replacing? I'm willing to give it a shot, but need some advice. Thank you in advance. Teddy,
  • 3 more comments
  • corayman Jan 01, 2009
    Hi, I tried the factory reset, the projected image is still bowed in with moving red lines, it did seem to group the lines together a bit more making the image a bit better,it has the 3D effect.you can't use the converge settings since the crosss move too much. The resolution I beleive all seems ok. Their is nothing new near the tv that should cause an electro magnetic effect.
    Hi, The Model # is 46PP930217
    Thank You, This answer sounds great, Im ok with electronics and can solder if needed
    Hi, My email is corayman@aol.com Thanks
    Thank You, I will recomend you to all in need. Happy new year.
  • 3,037 Answers
Hello corayman
The first thing you should try replacing which is most likely your problem in this situation are the ICs. There will be two of them on the convergence board they will be marked as STK-xxx (where xxx is a number). They are usually the culprit when these two colors go out of alignment and is the cheapest solution so hope that by replacing these you will fix the problem. Whoever replaces them will need to know how to solder and you can order new ones through an electronics store or from an electronics parts provider online. Let me know if you have any further questions about this, good luck.
bestdarngood
Posted on Jan 01, 2009
  • 15,935 Answers
If your good with a sodering gun and know how to work on printed circuit board, yes you can change the IC's your self for about 50 or so bucks, but if you have no solid state repair experience, I highly advise you to call a pro to assist you with this repair. You will need to get a service manual, the IC,s and then after that you would need to put the TV set into the service mode and make the necassary aligments to the set as well as the convergence circuit.
And I'm afraid that when the IC(s) blew out, it may have taken out a resistor or pico fuse out with it and you will now most likely need the service manual so you can check the voltages on the convergence IC's.
This is not a common DIY'ers fix. Please seek Professional help.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand if your TV is a Philips 46PP9302, then your describes problem indicates a convergence fault. The easiest way to go about this is to replace the entire board which would save you repair time although would be a bit pricey as well as challenging seeking a replacement/refurbished/repaired board. An alternative is component level repair where only the defective components (STK ICs, resistors and pico fuses) would have to be replaced.
If you are considering a DIY (do-it-yourself), please post back which level you would want to approach your concern, availability of a soldering iron, a DVM, a tester and a copy of the Service Manual.
Good luck and Thank you for using FixYa. Happy New Year.
  • 916 Answers
This sounds like you need to replace the color wheel.
  • 10,594 Answers
Its failure of convergence Out ICs and requires replacement of either ICs or Convergence Board.
Let me know model number to provide you technicla info to carry out repair process.
It is necessary that you should know electronics repair of TV and have related tools.
  • Shahid Electronics
    Shahid Electronics Jan 01, 2009
    Nice to know that you are good with elctronics repair and have solder skills.
    Thank you for accepting solution.
    TV needs STK392-12 quanitty 02 for correct convergence.
    Above part is available in Part Store.
    I would recommend to buy Service Manual of 46PP930217 from Manual Zone because service manual will give you complete technical info about schematics, voltage data, PCB layout etc.
    Good luck and Happy New Year.
    Genius:
  • 1,913 Answers
Reset all settings.
also check resolution.
also che k there is not any electromagnetic effect.
  • kishor khatri
    kishor khatri Jan 01, 2009
    uhave to take repair shop
    it need repairing.
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Red convergence problem
  • Screen looks 3D
Apr 07, 2009 | Philips 51PW9303 51" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
