Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My computer will not boot up.
It says missing or corrupt file \system\hal.dll. I tried rebooting from the cd and repairing it with setup. But, it keeps asking me for an adminstrator password, I don't know what it is. I have never set a password on my computer. It is a Dell Inspiron 1501. Thanks,
  • 102 Answers
First, if there is no password set you may be able to simply press enter leaving it blank and continue with the repair.
Alternatively, you can reinstall WIN XP over your existing installation which will replace your windows files with fresh copies from the CD.
Posted on Jan 01, 2009
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Nov 09, 2010 | Acer Aspire 4720 Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
Apr 30, 2009 | Dell Microsoft Windows XP Home Edition
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
"...missing or corrupt\system32\hal.dll..."
Boot from windows install CD, when it loads, press "R" for repair.
It will go out to dos.
when it gets to dos, type: CHKDSK C: /P then press enter and let it repair, when done
just type EXIT, it will reboot, remove the CD and see if it reboots. If this doesnt work or you need more help, let me know, i can be more detailed if you need, Im just at work and dont have alot of time to type.
Feb 17, 2009 | HP Pavilion zt1170 Notebook
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
